Bad insrument cluster?
Old Feb 17, 2010 | 09:47 AM
brama223's Avatar
brama223
2nd Gear
Default Bad insrument cluster?
Do these usually go bad and is there anything that I can try before replacing. I have taken it out and everything is tight. Is there any kind of fuse that may need to be replaced or something small I could start out with? It shows no speed or gas gauge or anything. It just went blank. It does light up however. Help would be appreciated as I am a new corvette owner with limited knowledge. If anyone has a cluster to get rid of, let me know. The year is 1990. Thanks.
Old Feb 17, 2010 | 12:38 PM
Mark85Vett's Avatar
Mark85Vett
notorious for failing..go to www.batee.com
Old Feb 17, 2010 | 01:35 PM
gbrtng's Avatar
gbrtng
Try these guys for repairs of the cluster: http://www.instrumentclusters.com/
After all the LCD segments go flakey, it's nice to know somebody can fix it.
They repaired Wifey's 91 coupe's cluster and I'm happy too.
Old Feb 18, 2010 | 12:06 PM
jhammons01's Avatar
jhammons01
OP, Don't pass Go, Don't collect $200....Go straight to Batee.com and read.
Your problem may be able to be fixed DIY for less that $50........You've already learned how to pull the Cluster....that is the hard part.
Old Feb 18, 2010 | 12:45 PM
kangi's Avatar
kangi
do it
Old Feb 18, 2010 | 01:12 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old Feb 18, 2010 | 07:14 PM
tblt44's Avatar
tblt44
I just got a used one for my 95 from e bay for 100 buck and everything works great.I is a different cluster
Old Feb 19, 2010 | 09:02 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Now take it apart, fix it, and keep it in the closet for a spare.
Old Feb 20, 2010 | 03:08 PM
brama223's Avatar
brama223
2nd Gear
Well, none of the tips from batee. com apply to my problems. It is only for 84-89 anyways.....Anything else I can try? Thanks
Old Feb 20, 2010 | 03:32 PM
engle1147's Avatar
engle1147
I'm surprised nobody jumped on that yours was a '90. If you've gone through the cluster's wiring harness pigtail with a voltage meter and have the correct outputs up to the cluster itself and are now convinced that you have a "cluster" problem then I recommend picking up a good "used" 90 - 92 cluster off of flEabay and doing a swap. The early ones are harder to find than the 94-96 versions. Beware that some that are "for sale" on that famous auction site may have issues/problems which the seller conveniently forgets to mention...that is why some are up for grabs for cheap $....not all but some. flEabay is buyer beware for the most part....you could get lucky though.
Old Feb 20, 2010 | 04:30 PM
kmillar's Avatar
kmillar
Default Cluster
Don't know if this helps or not...The problem I had on my '90 was that the numbers would jump all around then settle down, tried everything, finally phoned Gordon Killebrew before dropping money on a new cluster. He asked me to check the ground on the ignition coil, had a bad coil. problem solved
Old Jun 2, 2010 | 10:05 AM
krille's Avatar
krille
8th Gear
Default instrument
I have exactly the same problemon my -89 convertible, the background light is working but all gauges including speed and revs are dead.
any suggestions anybody? I doubt that all gauges are broken, more likely a common problem.
Old Jun 29, 2010 | 04:28 PM
grantar2's Avatar
grantar2
Bump
Old Jun 29, 2010 | 04:50 PM
vette079's Avatar
vette079
Maybe this helps;http://web.archive.org/web/200312071...=253&TopicID=2
Old Jun 29, 2010 | 06:29 PM
KEN W ANDERSON's Avatar
0KEN W ANDERSON
Former Vendor
We repair all 90-96 clusters for $225, unless the LCD is bad. GMComputers @770-777-1031
Old Jun 29, 2010 | 06:43 PM
gbrtng's Avatar
gbrtng
Are new LCDs available? What other repair work do you do?
Old Jun 29, 2010 | 11:17 PM
jfb's Avatar
jfb
There is a vendor on ebay that sells LCD's for $99 each.
To Bad insrument cluster?
Old Jun 30, 2010 | 02:50 PM
aklim's Avatar
aklim
Who is "we"? What is the company name? Thanx.
Old Jun 30, 2010 | 07:47 PM
magicforce's Avatar
magicforce
7th Gear
Try www.contemporary corvette.com thats where I sent my cluster I think they replaced the power supply.
Old Jul 1, 2010 | 10:23 AM
grantar2's Avatar
grantar2
Originally Posted by vette079
Thanks appreciate the information. My problem is twofold, the LCD part might apply, mine just disappears rather than scramble, but the check guages part has me concerned. Still might be connected.
Thanks again.
