86 vette tps question
Old Feb 17, 2010 | 11:07 PM
wstrysko's Avatar
wstrysko
Default 86 vette tps question
I have a 1986 vin 8 L98, that is giving me a code 21.
the book says it's because the tps was above 4.5 volts
at any time. I thought the setting was .54 volts min
and 5.0 volts at WOT. is this true? if so why would I
be getting this code?
Thanks for the help!
Old Feb 17, 2010 | 11:13 PM
megtom2's Avatar
megtom2
http://www.lbfun.com/warehouse/tech_...ch%20Paper.pdf
Old Feb 17, 2010 | 11:44 PM
wstrysko's Avatar
wstrysko
Thanks for the quick response !
I've read this article before, and followed this procedure,
but, what should the tps voltage be at wot ?
4.5 volts OR 5.0 volts?
the manual says 5.0 volts, but code 21 says tps voltage
was above 4.5 volts at any time, I'm still confused.
Old Feb 17, 2010 | 11:59 PM
megtom2's Avatar
megtom2
It has been a while since I set my 89 Formula's tps but I think 5 is a bit high. Somewhere around 4.5 is what you want to see.
Looking on the thirdgen.org website tells me anything over 4 is cool but needless to say you don't want it going over 4.5.
Old Feb 18, 2010 | 08:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2021.pdf
Old Feb 18, 2010 | 08:51 AM
AGENT 86's Avatar
AGENT 86
I'm still confused.
Just to clarify, they are talking about start up idle or when ignition was switched on(engine not running), ECM saw a TPS voltage greater than 4.5v.
Old Feb 18, 2010 | 09:36 AM
wstrysko's Avatar
wstrysko
Thank you all for you're help, I saw the check engine light come
on when i was driving it, and held it at wot for 5 sec. the
check engine light went off on it's own after 20 sec.
I'll set the tps at .54 volts and 4.5 volts WOT and see
what happens !
Thanks again !
Old Feb 19, 2010 | 09:25 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I don't think you can set the WOT, just set the idle at .54, and them MAKE SURE it doesn't go over 4.5 at wot.
i wouldn't worry about the top voltage at this point if it sets and runs without a check engine light.
Old Feb 20, 2010 | 01:41 PM
JAKE's Avatar
JAKE
Going from memory on this since it's been a few years since I had a 86.
You have a range within which the voltage is correct. It's .54 (+/- .075). That's measured with the engine "OFF", ignition key "ON". That's how the TPS voltage is set; OFF/ON.
Many guys shoot for the high side, like .61 or sometimes even more. If you go too high, a code will set.
Voltage above 4.0 tells the ECM that you're at WOT (even if you're not) and causes the ECM to enter Power Enrichment Mode; AKA PE Mode.
Using a digital volt meter, you can check your TPS by slowly opening the butterflies while watching the voltage readings increase. Numbers should NOT suddenly jump/skip. They should increase at the rate you're opening the throttle. Do it slowly.
Hope this helps.
Jake
To 86 vette tps question
