Differential Carrier Bearing?
Old Feb 19, 2010 | 10:45 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Differential Carrier Bearing?
I am getting a road hum coming out of my Dana 44 rear differential. I'm not sure but this might be symptomatic of a failing differential carrier bearing. I need advice on how to pin down this rear axle hum without tearing out the rear end for inspection. Any ideas?
Old Feb 20, 2010 | 07:24 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
you could lift the rear wheels off of the ground and support the car on jack stands.throw it in gear and listen.use a long screwdriver or pry bar to listen to the different areas of the rear.i had alot of noise,and i mean alot,coming from the rear of my car below 30 and worse below 18.ended up being my tires.sounded like a wheel bearing though.
Old Feb 24, 2010 | 02:39 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks.
I have always thought that the hum I get is just the Gatorbacks making road noise, but a shop mechanic recently said that he thought it was a carrier bearing. My sense is that he is wrong. Since the hum is not loud or anoying I think I'll wait a while and see what happens.
Old Feb 24, 2010 | 04:34 PM
ZRWHAT's Avatar
ZRWHAT
Originally Posted by pmihaltian
Thanks.
GATORBACKS, ARE YOU CHITTING ME?
If your still on Gatorbacks, your on borrowed time and should run right out and get a lottery ticket because you're lucky, just don't drive the car with the Gatorbacks to get to the lottery ticket store!.....
Out of curioscity, and while you're still here to answer this question, what is the manufacture date on you Gatorbacks?
Old Feb 25, 2010 | 11:27 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by ZRWHAT
Out of curioscity, and while you're still here to answer this question, what is the manufacture date on your Gatorbacks?
The Show Set is date coded 1987. The road set is dated 1996; okay lets hear it.....
Old Feb 25, 2010 | 12:08 PM
Mark85Vett's Avatar
Mark85Vett
Old Feb 25, 2010 | 12:09 PM
ZRWHAT's Avatar
ZRWHAT
pm,
I think you just found part or more of your noise source, tires have to be as hard as bricks, even the newer ones. Try swapping them out locally with maybe a friend or acquaintance with a known newer set from another C-4 and give it a try.
Problem with the older tires is they vulcanize or harden with time, so much so that they no longer absorb harmonics from the rotational roll of the tires, they start to transmit these bumps in the road and even the lug pattern of the tread to the suspension and through the car making one think they have a bearing starting to "hum".
Once in a hardened stage, these tires are more like plastic then rubber and a panic stop could be like being on "ice" even on dry pavement.
If you were closer, I've got a set of BF Goodriches you could try but I'm in Northern Virginia.
I'd try a swap before spending money on new tires, fresh tires will probably make it seem like a totally different car both ride and handling wise.
Good luck
Old Feb 25, 2010 | 03:06 PM
Pwnage1337's Avatar
Pwnage1337
LOL
Old Feb 25, 2010 | 03:07 PM
pmihaltian's Avatar
pmihaltian
Slingshot
pm,
Good luck
Thanks, Jeff. I know that you are right about the tires.
The 1987 tires are mounted on the original wheels and stay on the wall in my garage. I only use them for NCRS judging events. They only see about 50-60 miles a year and never at any appreciable speed.
The Z rated tires I use for regular driving, about 1500 miles a year, are in very good shape, but as you say they are pretty hard and at 30psi, they are somewhat bone jarring.
The problem that I have is that only BF Goodrich still makes 255/50 ZR 16" tires any more and I think that what they are offering for sale, while they say they are brand new, they are actually 7 - 8 years old. In the next year or so when my 1996 Gatorbacks finally bite the dust, I guess that I'll have to install the 17" wheel adapters and spring for some real new 17" Z rates tires. In the mean time, I'll just have to keep it under 140 mph.
Pete.
To Differential Carrier Bearing?
