New Best MPH
Old Feb 22, 2010 | 12:14 AM
Corvette0096's Avatar
Corvette0096
Originally Posted by Beach Bum
if you make the 10's with that combination, you'll be the first.
Man, I would have to find a skinny driver then.
I might have a buddy drive my car this season. He was number one in the world in 2008 Pro Bracket
http://www.nhra.com/etseries/pastchamps.aspx
Steve Kelly. Number one out of 33k people is not to bad huh?
Todd did you guys ever go to the extream like running 0 weight oil and running it on four quarts and take seats out of the car? You have your sway bar off? What shocks are you running and full slicks or ET streets?
Old Feb 22, 2010 | 01:43 AM
Beach Bum's Avatar
Beach Bum
No set formula, depends on many things. Motor for one, how much/where it makes its power. Ive seen 11 sec cars that only tra- 108-109
Yeap, I agree.... but it is hard for a street/strip set-up like our late model corvettes typically run to turn 121 mph into a 10 second timeslip.... but those stock eliminators have no problem with it....the below is one of my favorite video's....its a Mustang, but still a nice in-car shot of a very fun car.
http://www.musclemustangfastfords.co...deo/index.html
Old Feb 22, 2010 | 02:11 AM
Beach Bum's Avatar
Beach Bum
By coincidence, the Division 7 sportsman champion that year (Gary Hairfield) is a good friend of mine.... he used to hold the best et record in my car when I raced Carlsbad years back. He lost in the finals at Pomona in 2008, but he'll be back.... the guy has a knack for finding the winners circle. Plus, nowadays in Divison 7, they take the Race of Champions winner to the Finals at Pomona vs the main event.....thus you have to go through a lot fewer cars at the Divisional Finals to get back to Pomona.
No, I have never tried 0 weight oil...I run a full pan. I have removed the sway bar many years ago....(12lbs) I have had the passenger seat out before, it doesn't make a huge difference in et, its not that heavy... few hundredths ( I do not remember the weight) But, if you're ever at a 11.0x, pull it, you'll probably get what you're after. I run Monroe shocks right now, but that will be changing soon.... probably QA1's, but not sure. I run MT ET Fronts on a weld 15 x 3.5 rim and 26" x 11.5 x 16" ET Streets on a special edition Weld XP Series rim that was designed to clear late model brakes.
There are a lot of little tricks to finding a tenth or two..... none by themselves will do it, but they add up. Most important thing for you, is loosen that converter.... I saw its rated at 3k, but you were 60 footing high 1.5's on slicks..... on a sea level track in good air and a good track, at the traps you're running, you should be easy low 1.5's......some converters are different than others, even the same brand.....you can have a tight 3000 rpm converter that only flashes up to around 3200 rpm, or a loose one that flashes up to around 3800 rpm.... I think yours is on the tighter side for the rating. Do you know your true flash stall ? To me, that is the most important #......
A few easy things to do to find et, is first... drive straight... stay in the groove, a lot of bracket racers wonder why their et moved 2 or 3 hundredths from one pass to another with the same air.... they didn't drive straight and didn't realize it, it'll add-up if you make a 1/4 loop vs straight path. Of course shallow stage.... and I mean shallow stage. Most do not understand the importance of this when et hunting.... even a single inch will show-up on the timeslip... just barely flicker that bottom bulb. If you're going to run skinnies.... make sure you run the MT ET Front, its worth a couple hundredths vs a radial front skinny..... big difference in driven rotational weight. There are lots of little things..... I'd love to see you hit a 10 second et with that set-up.....what would be special about that is how docile of a set-up it is..... 219/219 @ .050" hyd roller cam and yet high 10's in a naturally aspirated 3200 lb car...... at least I'd be impressed.
good luck
Old Feb 22, 2010 | 02:26 AM
Corvette0096
I will have a buddy test it tomorrow. I have a two step in it now at 2k, if I add any more it will start pushing the car. I read on PI site that you get a free stall adjustment. I will get that loosed up some. I think 3800 is the target. Only problem i have is my car has the c-5 zo6 brakes on the front and skinnies are hard to find.
Old Feb 22, 2010 | 11:21 AM
cv67's Avatar
cv67
St. Jude Donor '05
Im wondering if youre ice skating on a normal basis if a 28" tire wouldnt help things out some.
Old Feb 22, 2010 | 11:40 AM
Corvette0096
What had happen was this, I pop a head gasket about 5 years ago. The car sat untill last year when I decided to get the thing fixed. I tried to sale the car last year but with the economy I knew there was no way that I would get what I wanted for the car. I ended up selling my slicks cause I was done with racing.
Well a buddy calls me up Friday and says that the track is open for a friends of family race. I said what the heck and ran my street tires. As you know you can't hook a street tire like you can slicks. I have to get some slicks.
Old Feb 22, 2010 | 12:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ah, ok didnt realize you were on street tires. Must have been a heck of a ride
Old Feb 22, 2010 | 02:36 PM
Hole-Shot's Avatar
Hole-Shot
121.04 at 12.667 On street tire. Track was a skating rink. Car has been sitting for almost 5 years.
Smoking
With my former 87, & a simular set-up to yours, my typical mph would be ~118 with a decent hook off the line. I did sneak into the 120mph range, but it would only happen when I spun off the line. Some people say that it is normal to gain mph w/spin off the line.
Around that same time period, Jay383 had simular experinces w/ the 120mph. (Jay now has a C5 ZO6).
I would love to see a SuperRam, 219 tap the 10s'. Good luck!
Old Feb 23, 2010 | 10:28 PM
thetoy's Avatar
thetoy
I'm glad you finally got the car back out thats a great mph. Next time you go out give me a call.
Old Feb 23, 2010 | 11:24 PM
Corvette0096
Will do.
Old Feb 24, 2010 | 10:07 AM
Snakecharmer383's Avatar
Snakecharmer383
Congrats on the new best MPH! I'm pretty impressed with that being on street tires. Best I could do with the stock goodyears was 12.6 @ 116
So I wonder if anyone will be able to hit high 10's in 2010 with our similiar set ups??
