Fuel Pressure Regulator install
Old Feb 21, 2010 | 02:48 PM
FOXX's Avatar
FOXX
Default Fuel Pressure Regulator install
Lost my FSM Can someone please look up how to do this? I have the plastic covers off now and it appears that I will need to disconnect the fuel lines to access the underside of the fuel rails. Also, do the injectors come out when I lift the rails? Any help would be just that. Thanks
93 6speed coupe
Old Feb 21, 2010 | 03:46 PM
sthamby's Avatar
sthamby
I just took the fuel rails off, 4 bolts, and disconnected the
one line going into the regulator. The injectors, if
they are original, will come out with the fuel rail.
