Please give me your educated opinion on this build. Car is a pleasure cruiser, not a 1/4 mile car. Looking for torque and a nice lopey idle. We are not doing heads as we have been lead to believe that the stock 113 heads can support up to 350 hp which this build should not go over.
I ask because I am toying with doing something similar but my budget would be minimal. Probably 1k or less if possible, I have too much interior work and paint I have to put money in to do a huge build.
what will that do for me that the hotcam won"t. I'm not challenging, just asking!
You always want to match your intake duration at .050 to the rpm band of the engine, and compression ratio. In your case, you will be RPM limited by running a stock length runner.
I would rather run a conservative cam, that a big one, and the 208 degrees of duration on the zz4 cam matches what you have nicely.
I am using the ramjet 350 cam. it is also used in the high torque 383. It is also referred to as a marine cam.
It supposedly has tremendous low speed torque and outstanding mid range torque.
I should have my engine together in a couple weeks, and will report on torque and how it responds to my driving and engine RPM band once it's in.
I have a 2.58 rear, and have a 3.07 that may find it's way into the car.
I will be changing the trans at the same time.
Hoping for the best since my engine right now cruises at 75mph at 1750 RPM, and I can spin the tires with ease with a healthy trans.
This hydraulic roller design is used on the 383 truck and Ramjet 350.
The duration at lash point in degrees (intake/exhaust) is 288/308; duration at .050" tappet lift (intake/exhaust) is 196/206 and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 431/451. Valve lash is zero/zero and lobe centerline is 109 degrees.
This camshaft is a great upgrade for 1996-2000 Chevy/GMC trucks equipped with the L31 Vortec 350 Engine. This cam is great for additional bottom end torque. If installed in one of these trucks, a custom computer re-program is needed.
Can somebody explain to me (in simple easy to understand language)
what the difference is between these two cams? What do these numbers mean to me as far as performance goes?
Also, does anyone know what the specs are for a stock L98? Just curious to see the difference.
ZZ4-Smaller Better suited to lower to mid rpm ranges
Hot Cam-Larger better suited to mid to higher range rpm ranges.
OK Pete, I understand what you are saying... and I kind of get that the lift is how far the valve opens and duration is basically how long it stays open but, when is too much lift or duration too much? Sorry to drag this on, I'm just trying to understand.
TPI/long tube runner setups really dont require much cam at all, usually the intake #@.050 in the 2-teens is plenty. Opposite of a typical short runner/carbureted motor.
