Ola. Hopefully someone who knows glue will read this! I need a glue that is as thin as water or close to and extremely strong. Anybody? Thanks! (Yes, this is a Vette fix!)
Two flat, high polished metal surfaces must never, ever come apart. It is an emblem and this is it - the high-lighted area is a very small seperate metal part that sits on top of the rest of the emblem. The back surface of the high-lighted piece is high polished metal, and the surface it sits on is high polished metal. I need to make this emblem so solid that it will be as one.
What would you do?
These little pieces are known to fall off these emblems and you can't find these emblems anywhere anymore. Thanks!
I would use a 1 to 1 epoxy. it is a bit thicker than water but just a drop should hold it. I have some i use to reshaft golf clubs so i don't think it would have a problem holding.
