does the color of the coil wires make any difference?
i replaced my 15yr old stock coil with red/yellow wires with a pertronix w/ red and white wires. this is the right one for 84-91 corvette according to summit; the accel model has red/white wires as well. is this the right coil?
also, i replaced the module as well with an accel module. an article i read said the coil and module need to match in order to work well.what do you think?
It shouldn't make any difference, but I would assume that the red wires on both coils are similar and connect them to the terminal the red wire goes to.
