L98 poor mans build?
Old Feb 23, 2010 | 12:47 AM
CooterCatchinVette's Avatar
CooterCatchinVette
Default L98 poor mans build?
Looking at these other builds i'm left wondering what you guys recommend for an absolute broke *** build. I have a 90' L98 with a rebuilt 700r4, Superior shift kit, Bosch injectors, and a new water pump. My eventual goal is to do a 383 stroker kit but that's down the line. What do you guys recommend for a broke @ss like myself for starters? I know I can change the gear out in the rear, get a dana 44, get a better cam, intake etc... but I guess being on a budget I don't know where to really start. I'm in contact with a buddy who can supposedly get the rear for dirt cheap, but I'm still waiting. My goal is to have a street car that is torquey as heck and has alot of HP. Something fun to drive (which it defintely is), and with a real whallop when I hit the accelerator. I know this is probably a retarded request but I'm wondering what some essential mods are. Any info would be great guys! Thanks! -Cooters
Old Feb 23, 2010 | 04:34 AM
catmech's Avatar
catmech
performance costs money, if you're flat *** broke start saving your penny's and upgrade later.. just my .02
Old Feb 23, 2010 | 04:55 AM
Weav's Vet's Avatar
Weav's Vet
I'm not real familiar with the L98's other than I know they have a lot of torque but if I were you I'd start with exhaust. You'll need that regarless of what you do down the road. Good Luck!
Old Feb 23, 2010 | 10:30 AM
cv67's Avatar
cv67
St. Jude Donor '05
what the essential mods are.
Wallet mod
Old Feb 23, 2010 | 10:50 AM
beerme's Avatar
beerme
I am with Cooter on being broke. Stock 1987 L98 with 93k, only mod already completed is smog delete and true dual's with melotone mufflers.
My budget is 1k plus labor, and I will need someone to install the cam if that is the recommendation as I don't have the ability to do it in my garage, ideal target horsepower is 300 at wheels. Is it possible?
Old Feb 23, 2010 | 11:03 AM
ch@0s's Avatar
ch@0s
Ck out vader's website
http://temp.corvetteforum.net/c4/vader86/
and ck this out good info on cams
http://www.z28.com/forum/showthread.php?t=79261
Here is a good thread on a 300HP l98
http://forums.corvetteforum.com/c4-t...00-hp-l98.html
Here is a thread with dyno #s for a full bolt on car
http://www.thirdgen.org/techboard/af...s-any-one.html
Cooter if I were you I would start on the supporting mods for your 383
Exhaust, intake, and gears
Old Feb 23, 2010 | 11:18 AM
engle1147's Avatar
engle1147
If your talking engine freshening up:
To redo the stock heads and bottom end your looking at $2k minimum for parts and machine work.
If your talking "bolt on" mods:
Free-er flowing exaust & a bit higher stall converter.
Best bang (hp/torque) for the buck:
Shot of NOS
Old Feb 23, 2010 | 02:00 PM
missinganova's Avatar
missinganova
mmmmm
If you heart is set on a stroker put the little cash that you have at this point into stuff that won't be affected down the line. Like when you win the lottery or whatever.
headers and mufflers
skip the cam because the grind won't be right for the bigger engine
skip a chip because that won't be right either
clean up the plenum and gasket match
rear gear to 3.54 or 3.73
plus the usual free stuff (smog delete, frisbee, throttle body coolant, etc.)
That 50 shot of nitrous isn't a bad idea either; wait a minute make that 75.
What do you think? All of this for 1500.00? You would need somebody to set up the pumpkin and cut and weld the exhaust yourself. You would also have to get the cheap *ss painted headers.
seeya I am going to Taco Bell for lunch; ding ding
Old Feb 23, 2010 | 03:45 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Your Vette reminded me of the 1973 Chevelle
Old Feb 23, 2010 | 04:49 PM
missinganova
You are correct; there are some similarities
The main difference is my vette has IRS with Dana 36 and the Chevelle has GM four link with corporate 10 bolt.
I even threw out the TPI/L98 combo and dropped in a 1973 vintage two bolt chevy small block with two piece rear main seal, hydraulic flat tappet cam, low flow low compression smog heads and Rochester qjet.
Once you get the bog out of the qjet she runs real nice at 14.7 stoich at idle.
LOL
Old Feb 23, 2010 | 05:03 PM
Bob Heine's Avatar
Bob Heine
It's not broke *** but you might want to check out Corvette Fever . They did a C4 upgrade in stages and called the thing Project C4orce.
Old Feb 23, 2010 | 05:17 PM
ch@0s's Avatar
ch@0s
This:http://www.corvettefever.com/project...car/index.html
He asks for a broke aszz build you point him to a lsX swap for 15k ..
Old Feb 23, 2010 | 05:40 PM
missinganova
It looks like they bought a 5.3 truck engine to put in a 2500 dollar C4 add another 12500 and end up with a car that is worth 10000.
makes sense to me.
Old Feb 23, 2010 | 05:49 PM
ch@0s's Avatar
ch@0s
makes sense to me.
Actually, I would love to do that swap but it ain't cheap brother
Old Feb 23, 2010 | 05:51 PM
missinganova
5.3 or 6.0??
Old Feb 23, 2010 | 05:56 PM
ch@0s's Avatar
ch@0s
5.3 or 6.0??
the the 6.0 but the 5.3 is still an LSX (we just hijacked this poor guys thread)
Old Feb 23, 2010 | 06:05 PM
missinganova
good point but I am crazy about the gen IIIs
junkyard low mile 5.3 for 350.00 around here; they are stacked to the ceiling! easy 350 horse without much more than a cam.
6.0 400 or 450 horse
and then the nitrous because of the six bolt mains...
To L98 poor mans build?
Old Feb 23, 2010 | 06:10 PM
pologreen1's Avatar
pologreen1
Wallet mod
Old Feb 23, 2010 | 07:45 PM
pearlvett's Avatar
pearlvett
I had my heads rebuilt, bought a complete cam kit from comp cams, and built and exhaust all for about 2k. I am in the process of buying some headers and a chip then im going to dyno it so i can see what it did
Old Feb 23, 2010 | 07:53 PM
ch@0s's Avatar
ch@0s
cool! I remember you asking questions a while back. What did you end up doing?
