vented opti vacume lines ?
Old Feb 24, 2010 | 10:33 AM
C4vettrn's Avatar
C4vettrn
Default vented opti vacume lines ?
Is there any parts other than the vac lines that I need for converting to the vented opti ? This is in regards to the vacume system only.
Old Feb 24, 2010 | 10:43 AM
surfer92's Avatar
surfer92
Yes, look in Tech Tips, there is a write up. Also, do a search, someone did a thread were they documented everything w/pics.
Old Feb 24, 2010 | 11:13 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Yes,
You need a manifold vacuum fitting under the T.B. if not there on the 92 and a fitting for the intake duct supply side as well as a small intake duct with the supply hole in it unless you decide to put a hole in your current duct. I have a decent used spare 94 duct with the existing supply port if interested. It does have a little rubber cement on one of the rib edges though to fix a small split but still works fine.
Rick
Old Feb 24, 2010 | 12:51 PM
dmukina's Avatar
dmukina
Here is a FANTASTIC article i ran into the other day. Its a HOW TO by corvette fever mag on switching your non vented to a vented!
http://www.corvettefever.com/howto/16758/index.html
Old Feb 24, 2010 | 01:12 PM
murray59's Avatar
murray59
Are you installing a vented opti or are you converting a non-vented unit?
Old Feb 24, 2010 | 07:18 PM
jwt1603's Avatar
jwt1603
Yeah, if you're getting a later vented one the connector is different. The later connector is longer.
Old Feb 24, 2010 | 08:53 PM
C4vettrn's Avatar
C4vettrn
I bought a vented OPTI for my timming chain/cover conversone.
To vented opti vacume lines ?
