just got C4 and need with help LT-1 engine
i just bought a 1994 c4 corvette with LT-1 engine / 6mt by the way i live in Kuwait . my car have about 202000 KM on the odometer. the car run great except for some small issues hope that i can find some answers here
some of the mods on the my c4 , installed on it when i bought it unknown milage on the mods
-BBK throttle body
-LT4 heads , pistons , cams
-3inch exhaust unknown brand
-head man headers
-force air intake system
did a compression test and it showed 76%.
get on subject issues
-at lower RPM the idle start to rumble then the car just shut down other than that no problem
-brakes barely stop i bush the brake pad al the way down so the brakes will stat working ( is it pads or brake lines ??) also some times the right back break grip
-when the transmission start to get hot from several hard runs its i hear a metal sound when i get it in 1st and 2nd gear
** also i have some picture that i need to know what are these peaces for
thanks for any input in advance
2. Check the brake pads and do a brake fluid flush.
3. Check fluid in the trans. Maybe do a drain and refill and check for any 'debris' in the old oil.
4. Easiest way to post pictures is to set up a free photobucket account and use it to post your pictures.
Hope this helps.
do i have to change the break line or just flush the fluid also use GM fluid or is there is other brands that is recommended
sure will do and let you know guys ,keep them coming
Again, check the brake pads. As hot as it gets in Kuwait I would go back with a top quality synthetic brake fluid. You said you have forced induction (supercharged or turbo charged) so you might also want to check vacuum to the brake booster. Low or no vacuum gives a very hard pedal and very little stopping. Does it have an auxillary vacuum pump? If the brake lines are not leaking they are probably not the cause, but check them for any cracking and replace them with Stainless Steel lines (Earl's or Goodridge) if in doubt.
http://s954.photobucket.com/albums/a...t=IMG_0036.jpg
sorry for the dirty engine bay but its really hard to keep it clean with the weather here
first of the black pipe that connected to the valve cover and throttle body is it vacuum line because is just notice its lose ?
second pic there is the pice of silver metal under the fuel line that is smashed and shut is it like this from the factory ?? what is it for ?? should b it be connected to something ??
the good thing is the labor is close to nothing
maybe 400 dollar to install SC/turbo/NOS on almost any car thats just an example. so tell your son to ship his corvette he's going have a pleasant time am sure if he's in modding cars
as to your second picture, LT1s used an EGR (exhaust gas recirculation)valve; LT4 did not need EGR, their longer duration camshafts provided "free EGR". The LT4 manifolds (red color is a dead give away) blocked off the EGR mount with a simple plate; someone cut off the tube from an EGR flange, flattened the tube, and mounted it in place of the stock LT4 block off plate.
The first picture is a tube used for the crankcase ventilation system; its not super critical but it should mount up snugly, not loosely.
also what do you recommend for pulley kit . am thinking of ATI pulley but i don't know what parts number pulley that will fit an LT engine and if there is something that is been used and proven for this platform ?
