Now i'm not sure if you need to remove the Bumper to get it out. I think on my 90 you can unbolt it. But I think because the guy who I bought my 84 from wacked it into his front garage wall that I had to remove my front bumper to get it out cause it was shifted to the right about 8 inches. Pipe
When I painted my 93 I removed them. There is a metal spring clip the pushes the lens toward the front away from a structural member right by the light (oriented vertically).
You take loose a couple of fasteners that hold the spring in place and tap the spring clip to the middle of the car as I remember. And it will release. Putting the clips back is more work than removing them. I didn't like the whole process but is cleverly designed by an engineer without enough supervision.
