Horsepower Vs. Cubic Inches?? Help
Old Feb 27, 2010 | 10:25 AM
cli59vette's Avatar
cli59vette
Default Horsepower Vs. Cubic Inches?? Help
Ok, so I have an SBC that was worked to a 355 and with the heads and intake produces 430HP. I was looking to buy a 383 short block and use all the components off my engine for the rest of the build. I am not sure what the HP would be? Do you guys think it's worth going to bigger CI if my engine can already push out 430HP as a 355?
355 SBC
World Products Sportsmand II heads (worked)
9.5:1 compression
Comp Cams TPI roller cam
Edelbrock ProFlo2 intake
Oppinions? Say what you think.
Old Feb 27, 2010 | 10:36 AM
engle1147's Avatar
engle1147
If your getting 400+ hp out of a 355 without power adders don't mess with it.
If your going to swap the existing guts out of the running 355 directly why not just overbore your current block if you want more cubes.
If your looking to go with "stroker" application that's a different animal.
Old Feb 27, 2010 | 11:48 AM
Red Rocket's Avatar
Red Rocket
355 SBC
9.5:1 compression
Not sure this is a valid input but someone told me a few years ago that 1CI was worth 1HP as a general rule.
My 350 made 365RWHP when I went to the 396. The 396 made 409RWHP after the change which is 44 more. Realize there are other factors to consider. With my new heads its even more now.
Old Feb 27, 2010 | 12:53 PM
cv67's Avatar
cv67
St. Jude Donor '05
The torque at all rpms is what will sell you on the 383. I promise you wont go back to a 350 after having the bigger motor. 33 cubes doesnt sound like much but it will take on a total different characteristic. Sure youll pick up some hp. If it were me Id cam accordingly, the 383 will make your current cam act a little smaller in sound and powerband also. Maybe step it up 6-8 deg duration @.050 to get about the same powerband you had with the 355
Old Feb 27, 2010 | 02:24 PM
Orr89rocz's Avatar
Orr89rocz
x2. Bigger is always better. YOur same combo now will make more than 430hp on a 383 but the torque is what really increases. Total area under the curve increases everywhere. I've seen some comparisons between cam only LS3's versus 416" LS3 strokers. Stock heads/intake just change the cam. Peak power went up 30hp and came in at a lower rpm. Torque went up 60 lbft. Look at the area under the curve
Old Feb 27, 2010 | 03:19 PM
383vett's Avatar
383vett
355 SBC
9.5:1 compression
It really depends on how you intend to use the car. If it is a strictly street motor, you are probably very happy and what you have now should be fine. If you're going to visit the track or dragstrip regularly, you can never have enough horsepower.
Old Feb 27, 2010 | 04:40 PM
frenchyoliver's Avatar
frenchyoliver
my 331 output more than 600 rwhp at 8400 rpm.
because of destrock pistons profile, it allow higher rpms with high comp ratio...
going the other way 383 stroker requires way more energy to deploy in order to achieve it and you stay low rpm zone at 6000 anyway. Way too low.
Even if you eventualy can reach more HP with more cubic inchs, its all a question of balance first to get the best HP/displacment ratio.
For exemple, my honda CBR 1000 (1 liter) output 190 hp. Means its a about the same as a first gen C4 with 6 times less displacment ( 350 CI 5.7L).
Old Feb 27, 2010 | 04:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
So tell us about this 331
Old Feb 27, 2010 | 04:52 PM
frenchyoliver
look at sig
PS: sorry: specs are for 355 inside the C5R.
331 is the C4 GT1 is around 520 hp at 8200 rpms.
Old Feb 27, 2010 | 05:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Which one is which, what internals?
Awful hard to get 500chp out of a 331 let alone 600rwhp.
Old Feb 27, 2010 | 06:45 PM
JAKE's Avatar
JAKE
We're looking at 1.57 HP per cubic inch to hit 520. Are we referring to NA?
Jake
Old Feb 27, 2010 | 08:26 PM
vettme's Avatar
vettme
355 SBC
9.5:1 compression
THERE IS NO REPLACEMENT FOR DISPLACEMENT. More CI will give you more HP/TQ. That being said you may need a different cam with the larger CI . Im sure some one here has the same combo. I dont think going from a 355 to a 383 is enough of a diff to go thru ALL the work. IMOP. Good luck
Old Feb 27, 2010 | 08:40 PM
tpi 421 vette's Avatar
tpi 421 vette
As inexpensive as it is to build a 383, I don't build 350 or smaller motors. A 383 really isn't any more money to build than a 350. Like mentioned, the torque of a 383 is a day/ night difference over a 350. Our cars are heavy by race car standards, and the extra torque makes a huge difference getting that weight moving.
Old Feb 27, 2010 | 10:35 PM
cli59vette's Avatar
cli59vette
Thanks for the imput guys. The engine puts out about 475lbs of torque and it is going into a 59 vette that i will drive more like a granny. yes i'll have some fun with it. but it'll never see the track. it's a toy car to have fun with.
so with that said, if my 355 has 430hp/475tq, would you all agree that it's plenty for a cruiser which is what i am intending the car to be in the first place?
thanks guys.
Old Feb 27, 2010 | 10:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
I dont see the 355 making 475lbs, a stroker will. No need for a high rpm motor for what youre doing.
Old Feb 28, 2010 | 12:30 AM
Orr89rocz's Avatar
Orr89rocz
Guy on thirdgen just dyno'd his superram 383 and it dynos 517 or so peak torque, but it has 500 as low as 2600 rpm where the dyno run started. Keeps over 500 lbft from 2600 to 4500 rpm. IT has 467hp at 5500 rpm. Nasty street motor there. It probably has over 400lb ft off idle! That will get a car moving
Old Feb 28, 2010 | 03:49 AM
5abivt's Avatar
5abivt
Those are great numbers !!
To Horsepower Vs. Cubic Inches?? Help
Old Feb 28, 2010 | 05:21 AM
frenchyoliver
classic stuffs.
HTC Crank, Carillo 6.2 inch rods with CPX forging pistons, SB2 NCN Block, prepared by rocket engine devlopment, 11.5 compression ratio, 114 octane fuel, full hand ported LaCross heads with exceldyne titanium pushrod & valves, crower extreme duty roller liffter with pin oilers, Jesel Cam drive and rockerarm setup, custom MSD ignition, Barnes 5 stages oil pump, carb. 830, custom exaust etc etc....
We dynoed it at 560 hp @ 8400.
I dont agree about "there is no replacement for displacement", this is old "muscle car" 70 s mentality.
High displacement means extreme high cost if you want to get up the RPMs. 6000 rpm is low.
did it once on a viper and it costed me more than 50.000 $ for engine.
My C4 GT1 engine only start to output tons of HP a 6000 rpm till 8400.
Old Feb 28, 2010 | 08:01 AM
aboatguy's Avatar
aboatguy
classic stuffs.
Your engine looks SWEET! I agree that high revs are great......Zipping along with the V8 engine at 6000, 7000 rpm or even higher is a wonderful thing (sadly my LT1 is limited to 7005 rpm via the factory PCM)
Great avatar...Superdupont, however, most Americans will miss the Humor/Irony of your choice.
Old Feb 28, 2010 | 09:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
Nice but the OP sounds like he just wants a street motor to play around with. An SB2 wouldnt be much fun on the street;track terror, yes
