Ported MAF Causing Problems?
Old Feb 27, 2010 | 10:49 AM
Digital Disaster's Avatar
Digital Disaster
Default Ported MAF Causing Problems?
Has anyone here experienced intermittent "lean condition" codes because of ported MAF housings/no screen, etc?
I've got a TPIS ported MAF housing & removed screen and crossbars in my MAF, and am getting a P0172 code that sets the second it goes into closed loop. I can clear the code and it doesn't come back until next drive.
I've read that modifying the MAF can cause this. True?
Old Feb 27, 2010 | 10:53 AM
engle1147's Avatar
engle1147
Are both ends of the MAF without screens?
The screens act as difuser to allow the air to flow evenly over the heated elements. Some have removed them with no problems...but the screens are there for a reason.
Old Feb 27, 2010 | 11:07 AM
Digital Disaster
Yes, both screens gone when I got car and never any codes.
I added the ported housing and per TPIS instructions removed the "extra" crossbar material. These codes weren't immediate, and are intermittent, so I didn't associate them with this mod right away.
Old Feb 27, 2010 | 11:20 AM
engle1147's Avatar
engle1147
The extra "less" restrictive diameter of the housing may be allowing an uneven flow reading...if the housing was all you changed.
Might be worth a shot:
If you have an extra bit of "widow" screen (plastic) from a home improvement store you could stretch it across the face of the MAF (on the incoming air side) and let the air filter housing/clamp hold it in place to see if the codes subside while the screen is in place. This should create a more even flow across the MAF element....just make sure it doesn't get sucked in.
I'm not sure how the plastic screen would hold up over extend heat/time so your on your own with that aspect.
Old Feb 27, 2010 | 11:21 AM
STL94LT1's Avatar
STL94LT1
You may need a new tune to work with the MAF. From evertything I've read ported MAF's are more problems than they are worth. But good luck with yours, maybe you will prove me wrong.
Old Feb 27, 2010 | 11:43 AM
Digital Disaster
Thanks for the input, I'm going to contact the tuner, Ron Zimmer at Z Industries, to see if he can adjust for the added airflow.
Old Feb 27, 2010 | 11:53 AM
427c4vette's Avatar
427c4vette
By "extra" crossbar material you mean the heat sink fins, right? Your lean condition is caused because the heated wires "see" only a small percent of the air flow going through the housing. Once you gut the housing the percentage of total air flow the wires "see" is less. Putting the trash screens back on will probably have no effect.
When I gutted my MAF I also ported the heads , bigger camshaft and increased the fuel pressure and had no problems with codes being set.
If you have an adjustable fuel pressure regulator you could try increasing the fuel pressure. A tune will correct the problem. You could also try replacing the fins with a small lump of epoxy to change the percentage of air the crosshairs see. I would try the fuel pressure regulator first and a tune second. I hate the thought of a piece of epoxy coming loose and entering the engine or damaging the cross hairs.
Old Feb 27, 2010 | 12:07 PM
Digital Disaster
The engine is a 383. Around the same time I did the ported MAF housing I also switched out the shortie headers for longtubes, and installed 3" high flow cats, and 3" B&B exhaust - I have a feeling this may be contributing to the lean codes, though I was told the changes shouldn't require retuning.
Old Feb 27, 2010 | 12:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
You should really retune it.
If something, a little piece of debris hits that filament it will make that MAF useless and cause it to go lean. Happened to my 78 (descreened). THere were teeny pieces of leaves in there, guessing at some point the filament got tagged. Car would go intermittently lean, drove me NUTS trying to find the problem. Eventually it blew the head gasket.
Old Feb 27, 2010 | 10:55 PM
cryvette's Avatar
cryvette
Here's my two cents.I did this mod awhile back and my 86 L98. It is working fine so far. I did ported the plenum and add an adjustable fuel pressurer regulator and true dual exhaust and vortex breather. I'm hoping I don't start get codes.
Old Feb 27, 2010 | 11:10 PM
cwyates4's Avatar
cwyates4
well, you are obd2 and i am obd1, but I've never had a problem with mine at all. But i have heard, like others have said, that if the air doesnt hit the element right it will cause problems.
To Ported MAF Causing Problems?
