HURST INSTALL
Old Mar 9, 2002 | 12:24 PM
STL94LT1's Avatar
STL94LT1
Default HURST INSTALL
Is it really necessary to drop the exhaust during the Hurst shifter install ?
Old Mar 9, 2002 | 12:45 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: HURST INSTALL (STL94LT1)
YES
Definately do it! It is possible to install the Hurst with the exhaust in place, but I hope your into micro-surgery :D . The 20 minutes it takes you to unbolt/remove the exhaust will save you alot of time in the installation process. That rubber shift boot is tough to negotiate.
Old Mar 9, 2002 | 09:25 PM
enhance's Avatar
enhance
Looks like it would make it a hella lot easier. When I did my install I couldnt see a way to do it without removing the exhaust,
but people have done it before.
Old Mar 9, 2002 | 10:12 PM
STL94LT1's Avatar
STL94LT1
Default Re: HURST INSTALL (enhance)
Thanks guys, sounds like I will be dropping the exhaust. I am going to install the Hurst on Easter weekend, and didn't want to do any unnecesary work.
To HURST INSTALL
