Timing?
Old Feb 28, 2010 | 04:44 AM
zeek racing's Avatar
zeek racing
Default Timing?
What should I set the timing at on a 85 tuned port?
Old Feb 28, 2010 | 05:53 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe your '85 is same as my '88, i.e. 6deg BTDC, though I like to run 8deg BTDC for a little crisper throttle response.
Old Feb 28, 2010 | 12:23 PM
jan-erik's Avatar
jan-erik
Hi.
The 85 is sensitive for knocks and with 8 BTDC may be too much. It depends also of the fuel. Even thought the engine do not knock when driving it may knock and the ignition is turned back and you lose power.
I am not sure about the adjustment if to do it for less knocks without the closed ignition regulation loop.
Old Feb 28, 2010 | 08:34 PM
zeek racing
Thanks for the help!
To Timing?
