I can't open my hood on my 91. The left side seems to release but not the right. HOw can I access it to release it?
You will need to make a tool from a bent metal rod or other similar item - it will need to be 8-10 inches long, with a 90 degree bend at the end, and 2 inches of metal after the bend.. kind of like a long "L" shape. Using this you can trip the latch manually, by fishing around in there with the tool. The latch assembly is on either lower front corner of the windshield.
Try it with some help. Have a friend push down on the stuck side and hold it down. Pull release and hold release all the forward and have friend pull up on stuck side at same time. Check for alighment of pin and make sure it's lubed.
A friends 87 stuck a while back. It took about 5 minutes to bend a steel rod I had laying around and 10 minutes of fishing around under the hood until it opened. Not bad overall.
It helped that we could use my 92 to get the correct distance to the latch. Notice the black stripe on the tool? That tells you how far in to insert it.
