- How to Replace Convertible Top
Step by step instructions for do-it-yourselfers.
Browse all: Exterior How-Tos
c4 convertible top replacement
I posedt a tech tip on this many years ago. Sadly, the old tech tips seemed to have been mangled a bit. Early Convertible Top Installation and Glass Retrofit
The one pitfall I had is to make sure you get every bit of old glue out of the rear bow. The glue is the only thing that holds the rear of the top on and it has a LOT of pressure and if you have ANY old glue left on therear most bow the glue will not hold and you will have a mess!
I found that it was easier to replace the warn out pieces of weatherstripping as they seem to disintegrate if you just try to remove them.
I got a Robbins top and it has held up well over the years.
I know that Ecklers sells tops I wanted to save some money so I could replace engine in my car so I was going to attempt to do it but maybe I should bite the bullet.
