Keyless entry remote question.....
Old Mar 9, 2002 | 09:25 PM
Hi-psi's Avatar
Hi-psi
Default Keyless entry remote question.....
Guys,
Picked up a Vette last week. I found a keyless remote in the console. It didn't work, so I assumed it had a dead battery. Bought a battery for it and now I'm told it has to be programmed. What is the procedure for doing this? Thanks.
Old Mar 9, 2002 | 09:46 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: Keyless entry remote question..... (Hi-psi)
Check ur mail.........
Old Mar 9, 2002 | 10:17 PM
Hi-psi's Avatar
Hi-psi
Default Re: Keyless entry remote question..... (lou sylvestri)
My website and mailserver are down right now so my mail isn't working. Could you either post here or e-mail me @ boostedta@yahoo.com
Thanks.
Old Mar 9, 2002 | 10:39 PM
TVS VETTE's Avatar
TVS VETTE
Lou Sylvestri has helped me back in dec when I bought ours. He is the man. Follow directions Tim :seeya :seeya
Old Mar 9, 2002 | 10:54 PM
Admiral Fairway's Avatar
Admiral Fairway
I think I have the procedure, I am reading it out of the service manual;
Always make sure the radio is turned "OFF" while programming the PKE system.
1) ignition key in the run position
2) trip ODO button is pushed and released
3) trip ODO is pushed again and held for 5 seconds
4) within 5 seconds push and hold the fuel info button for 10 seconds
>the passive keyless entry telltale lamp will come on continuously
5) ignition to the "LOCK" position.
>the passive keyless entry telltale lamp will now begin flashing
This is where I am not sure, but I think you shake the key fob and this should set the code for this transmitter. Remove the key from the ignition to end programming. Hope this helps.
This is the procedure for a '94, should be the same for a '95.
[Modified by cnl3rd, 9:54 PM 3/9/2002]
Old Mar 9, 2002 | 11:27 PM
Rich_01659's Avatar
Rich_01659
Default Re: Keyless entry remote question..... (cnl3rd)
I just replaced my passive key chain. Here are the directions straight from the box.
1 Place the transmitter and any optional transitters 10 ft or more away from the car.
2 Turn the ignition key to the ON position
3 poush the TRIP/ODO button twice
4WITH IN 5 SECONDS push the FUEL/INFO button until the PKE light on the driver information center stays on.
5Turn the ingition OFF, but leave the key in the ignition... The PKE light will begin to flash.
6 Ready to program! Bring the first Transmitter into range. Once the system has programed the Flashing will pause. Repeat step 6 for each transmitter.
7 Remove the key and your done.
Good luck
Old Mar 9, 2002 | 11:28 PM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
Very easy I did it myself, just follow these directions and it works. BTW you're lucky to have gotten one, I didn't and had to pay $90 to get one :eek:
Old Mar 9, 2002 | 11:57 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Keyless entry remote question..... (thrills)
I got lucky, one of the mechanics at the dealership gave me one for free!
Old Mar 10, 2002 | 12:14 AM
Hi-psi's Avatar
Hi-psi
Ok,....I tried both procedures listed and I can't get the PKE light to come on.
I pressed the Trip/ODO twice, then within 5 seconds pressed the Fuel Info button and held for at least 10 seconds with the key on. Nothing.
I tried the other method listed. Pressed the Trip/ODO, pressed it again holding for 5 secs.....then within 5 secs press and hold the Fuel Info button for at least 10secs,.....still nothing.
What am I missing???
Old Mar 10, 2002 | 01:12 AM
IcemanZ06's Avatar
IcemanZ06
Hipsi, I have been through exactly this situation and it took me 2 weeks to find out it was something so obvious I couldnt belive it. The instructions Rich posted are indeed the correct ones and are the ones I used a few days ago when I got it to work. After pressing hte Trip/Odo button twice you will need to hold the Fuel/Info button for around a minute or so. I would do this and my light would never come on. Guess why? MY LIGHT WAS BURNED OUT!!!!
:mad
Go figure it was something that easy, and here I was looking at wiring diagrams and everything. Just do as the instructions say, hold the fuel info button for around a minute and even if the light doesnt come on try and continue as the instructions imply. worked for me :crazy: :cheers:
Old Mar 10, 2002 | 10:36 AM
dtw50's Avatar
dtw50
Default Re: Keyless entry remote question..... (Rich_01659)
I can vouch for the procedure that Rich posted. I just did this yesterday in my '96. Of course, that doesn't mean that the '94 is the same.
Old Mar 10, 2002 | 03:04 PM
Red Dwarf's Avatar
Red Dwarf
Just a suggestion....I would move the FOB
more than 10 ft.. Thats right on the fringe of its range. Try 20 or 30 ft???? :boxing
To Keyless entry remote question.....
