Distributor part#
Old Mar 3, 2010 | 09:26 PM
C-4 owner's Avatar
C-4 owner
Default Distributor part#
I was wondering if anyone has a GM part # for the wire harness that goes into the distributor.This harness comes from the main(4 wires)and goes into the dizzy and hooks up to the module.
Old Mar 3, 2010 | 11:23 PM
John A. Marker's Avatar
John A. Marker
I don't have the part number, but I believe that you are referring to the distributor terminal board. It links the wiring harness to the ignition module in the distributor. You should be able to get this at most parts stores.
Old Mar 4, 2010 | 11:15 PM
Ning_85_vette's Avatar
Ning_85_vette
I think he is asking about the jumper that goes from the Firewall and is 4 wires and goes into the distr. the wiring that was linked is a 3 wire and goes from the distro into the coil on top of the distro.
Old May 28, 2024 | 09:26 PM
Chad parker's Avatar
Chad parker
2nd Gear
My car was stolen and this tan wire is not connected I believe it has a resitor in the middle but I can't find where the end away from distributor connects
Old Jun 1, 2024 | 08:03 AM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
This thread is fourteen years old. You may have better luck stating your problem in a new thread.
To Distributor part#
