engine swap?
Old Mar 4, 2010 | 11:27 AM
lucster's Avatar
lucster
Default engine swap?
what to expect. going from stock tpi to blown 383 carb engine from 1989. my vette is an 85. I just really want all my gauges to work. will the tach work with MSD? any info. greatly appreciated
Old Mar 4, 2010 | 11:51 AM
engle1147's Avatar
engle1147
The gauges should work fine. What's the deal with the old '85 block?
Old Mar 4, 2010 | 01:16 PM
lucster's Avatar
lucster
its perfect 56k original miles. im just a hp junky and i already have the 383 stroker with performer heads and b&m 144 blower pushin 5 with the right tune. the oem tpi is for sell with harness and computer.
Old Mar 4, 2010 | 01:23 PM
engle1147's Avatar
engle1147
List that thing for sale in the F/S section......people will ****** the puppy up quick.
Old Mar 4, 2010 | 01:25 PM
lucster's Avatar
lucster
thanks http://forums.corvetteforum.com/c4-p...nal-miles.html
Old Mar 4, 2010 | 03:56 PM
lucster's Avatar
lucster
how does it get the estimated fuel mileage?
Old Mar 4, 2010 | 04:29 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
If you swap to a carb, I think you will lose that function.
Old Mar 4, 2010 | 04:33 PM
lucster's Avatar
lucster
can you think of any thing else? guess the check eng. will be glowing!
Old Mar 4, 2010 | 05:22 PM
383vett's Avatar
383vett
You will lose the mpg and range functions. The check engine light will not light up since the ecm will be in your cabinet somewhere. That's where mine is.
Old Mar 5, 2010 | 12:06 PM
lucster's Avatar
lucster
how hard is it to separate wires from the harness for all the gauges?
Old Mar 10, 2010 | 09:24 AM
lucster's Avatar
lucster
pull from the side or remove the hood? trans and motor? or just motor?
Old Mar 10, 2010 | 11:43 AM
rlane5's Avatar
rlane5
It's less work to pull from the side and just pull the engine, if the transmission is in good shape. But I'm quite sure you know that, the blower will not sit under the hood, without a larger scoop or changing too a aftermarket hood. So it's going to need to come off either way.
Randy
Old Mar 10, 2010 | 11:54 AM
lucster's Avatar
lucster
yea, i was gona chop a hole in it. I bought a old school aluminum bird catcher.
Old Mar 10, 2010 | 12:01 PM
lucster's Avatar
lucster
like this but lot smaller lol
Old Mar 19, 2010 | 12:02 PM
lucster's Avatar
lucster
pro gress
Old Mar 19, 2010 | 07:42 PM
lucster's Avatar
lucster
Old Mar 27, 2010 | 11:35 AM
lucster's Avatar
lucster
moved to http://forums.corvetteforum.com/c4-t...post1573563637
Old Apr 7, 2010 | 11:46 AM
lucster's Avatar
lucster
fuel pump no worky?
To engine swap?
