86 instrument cluster problem
Old Mar 10, 2002 | 05:08 AM
Sharky Guam's Avatar
Sharky Guam
Default 86 instrument cluster problem
I just bought an 86 with an instrument cluster problem. the cluster lights up. But everything indicates a maximum value. I cannot be doing max rpm and max mph while I am sitting still in the parking lot. Is this a simple fix, or do I need a new cluster assembly? I was hoping that it is a simple power source problem. :confused:
Old Mar 10, 2002 | 06:19 AM
drive it's Avatar
drive it
Default Re: 86 instrument cluster problem (Sharky Guam)
Does the oil press. etc. also show max values? If so, then it's definitely an open-check the plug; the wires can loosen in the connector.
Old Mar 10, 2002 | 06:21 AM
Sharky Guam
Default Re: 86 instrument cluster problem (drive it)
Yup. everything is going sky high. I will recheck the wiring and the connector. thanks! :cool:
Old Mar 11, 2002 | 02:52 PM
black86targa's Avatar
black86targa
a few of my backlite bulbs quit working but gauges are fine. Dealer wants $110 to just replace those bulbs. I just ordered a complete rebuilt unit from Corvette Cluster Service in Indiana for $200 exchange. They say its a 20 minute job to change it. Instructions included. Mine is also an 86.
http://www.corvettedashclusterservic...oprocess1.html
Old Mar 11, 2002 | 02:56 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: 86 instrument cluster problem (black86targa)
Takes about 15 minutes and $4.00 of bulbs to replace, if you want to do it yourself!
Pete
Old Mar 11, 2002 | 06:51 PM
vader86's Avatar
vader86
AT most, it will cost you $40, the sylvania 882s are kinda expensive. The dealer is smoking crack to charge that much.
To 86 instrument cluster problem
