low coolant light (1987)
Old Mar 10, 2002 | 07:55 AM
MITCH's Avatar
MITCH
Default low coolant light (1987)
i have changed the sensor twice i have packed the rad 4 times. changed the rad cap i have no leaks car does not run hot.
any ideas help please!!!!!!
thanks in advance mitch
speednut2@aol.com :confused: :confused: :confused: :confused:
Old Mar 10, 2002 | 12:34 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: low coolant light (MITCH)
I'm reading the Helm and there are 2 (14,15) codes for coolant temp. If you have a scan tool it would be easier to diagnose the problem b/c the first test on both codes is to hook up a scan tool. You changed sensors already so after that would be to check for a short in the yellow wire, open sensor ground circiut, faulty connection at ECM or faulty ECM. HTH a little.
Old Mar 10, 2002 | 08:30 PM
BBA's Avatar
BBA
My 87 was setting the light off a lot until I started rotating ( I spun it 180º ) the actual sensor/switch installed position...now it works fine.
Old Mar 15, 2002 | 04:38 PM
MITCH's Avatar
MITCH
thanks for the replys i will check it this weekend :chevy
Old Mar 15, 2002 | 06:56 PM
John G 92's Avatar
John G 92
My 87 dose the samething ever once in a wile the low coolant light will come on and go off and the level is fine. :confused:
Old Mar 16, 2002 | 07:39 PM
MITCH's Avatar
MITCH
this car is driving me nuts i tried all of the above things but it still comes on
engine temp is 175 to 185 does not run hot and thermo is opening and closing any ideas i am lost need help.
mitch
Old Mar 17, 2002 | 12:37 AM
Raidmagic's Avatar
Raidmagic
I have an '87 and since I replaced the rad. my light comes and goes as it pleases the car doesn't run hot or leak.
Old Mar 17, 2002 | 04:32 AM
Ezgoin721's Avatar
Ezgoin721
I have the same problem on my 87. I read an artical a while back that listed about 10 common causes for this problem. I finally got tired of chaseing the problem and just ignore the light as it comes and goes. :cuss
Old Mar 18, 2002 | 02:56 PM
purple jinx's Avatar
purple jinx
Default Re: low coolant light (John G 92)
ditto!
Old Mar 18, 2002 | 03:10 PM
Hawaii89vette's Avatar
Hawaii89vette
I had the same problem too. On mines, I noticed that the light came on when the temp reached the thermostat temp. The coolant wasn't being pulled from the overflow tank. What I did was put some of that Bar's Leak Radiator leak sealing powder in and the problem went away.
-Tim
Old Mar 18, 2002 | 03:48 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: low coolant light (BBA)
My brother's '87 had that problem and I did exactly what BBA did... voila!!
Old Jun 28, 2013 | 04:20 AM
toboss's Avatar
toboss
1st Gear
Default corvette
What did you spin mine dose it at about 210 then will not run with out constant pressure to gas pedal
Old Jun 28, 2013 | 09:08 AM
pmihaltian's Avatar
pmihaltian
Slingshot
You have to drill two small holes in your thermostat, then refill the system and properly burp your cooling system.
I had this problem for years and tried ALL the things mentioned above. I repacked, repacked AND repacked, all to no avail.
Once I drilled the thermostat holes and properly purged the system - THE PROBLEM WAS FINALLY SOLVED. Check it out.
Old Jul 2, 2013 | 08:43 PM
Bon Air's Avatar
Bon Air
My '87 light used to go on/off, I made sure the overflow tank was at least half full, it replaced the level in the radiator as fluid is circulated in the engine. Light went off.
Bon Air
Old Jul 3, 2013 | 02:59 AM
Cliff Harris's Avatar
Cliff Harris
My low coolant light came and went until I replaced the radiator cap. I have heard of others fixing theirs the same way. Strange but true.
To low coolant light (1987)
