Ignition
Old Mar 7, 2010 | 05:51 AM
ndanl's Avatar
ndanl
Default Ignition
my 1991 corvete has e stock distributor, is it possibile/hard to replace it with HEI distributor ?
10x
Dan
Old Mar 7, 2010 | 06:27 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
No need to replace the dist, just do the cap.
I installed a HyperTech Coil/cap/rotor combo; it puts out 54kV up to around 6k RPM whereas our stock unit rolls off around 5k RPM.
Old Mar 7, 2010 | 07:55 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
10x
Dan
Your stock dizzy, is a HEI distributor.
Old Mar 7, 2010 | 11:26 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
your stock distributor has a 7 pin module in it. Be sure if you change it, you get a module for your car that has 7 pins. The Module controls the coil saturation and provides computer information for engine timing..
Other than that, get a higher voltage coil, better cap, etc.
Old Mar 7, 2010 | 12:47 PM
ndanl's Avatar
ndanl
ok, I found some kits on summitracing but my cap is mounted with screws, see pic, how can I mount the cap from these kits ?
Old Mar 7, 2010 | 01:22 PM
ndanl's Avatar
ndanl
or can I buy only the coil ? like this one ?
http://www.summitracing.com/parts/SUM-850011/?rtype=10
I have a new cap, rotor, 7 pin ignition module and all, just the coil is the old one
To Ignition
