does anyone here use amsoil?
Old Mar 9, 2010 | 07:51 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
Default does anyone here use amsoil?
i work in a shop that builds custom jeeps and rock buggies and we are an amsoil dealer.i get a good deal on the stuff and ive heard some good things about the products they make.does anyone have any experience with it and would you use it?
Old Mar 9, 2010 | 09:09 AM
boonie c4's Avatar
boonie c4
I've used Amsoil 5w30 tranny oil in both my 93 and 94 ZF tranmission Corvettes with good results, Amsoil has a good reputation for making superior lub products. In my opinion:go 4 it!
Old Mar 9, 2010 | 05:05 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
For the past 5 years (75K) I've use Amsoil products in my 95 for the engine, trans and rear diff.
Old Mar 9, 2010 | 08:06 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I have been using engine oil (20/50 Gold) and ATF in tranny and power steering since 1998, over 80,000 miles ago (150,000 on car now)
Just removed valve covers for RR install and amazzed! Inside shiny, heads look line new
It's pricey but well worth it! I haven't changed tranny fluid and it is still clean. I change engine oil every year, like 7000 miles
Old Mar 9, 2010 | 09:53 PM
tblt44's Avatar
tblt44
My father uses amsoil in everything from his SSR, 4 wheeler to his boat.
I just stick with Mobile 1 in everything,engine ,trany,gear lube
Old Mar 9, 2010 | 11:40 PM
kangi's Avatar
kangi
I use amsoil in everything I own...It helps that they make it here and I've got some friends in the biz...
Old Mar 10, 2010 | 03:55 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Keep in mind, Eaton recommends mineral/petroleum lube for our positraction carriers (click this link and scroll to "Eaton Posi"):
http://www.eaton.com/EatonCom/Produc.../FAQ/CT_128414
There's a friction 'zone' between too much slippage and chatter/bumping where limited slip (positraction) effectiveness exists and the engineers at Eaton know how that's achieved.
Also, I believe GM recommends a Synchromesh lube for ZF's. I'm not sure if Amsoil makes a syncromesh lube, but I'm staying with GM's recommendation.
For my money, I'm not going to dismiss the recommendations of the engineers and their R&D when it comes to lubes.
FWIW
Old Mar 10, 2010 | 03:58 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I replaced all the fluids (engine, trans, and diff) with Amsoil and picked up 2 MPG on the highway. I also track my car on roadcourses and the Amsoil hold up very well.
Old Mar 10, 2010 | 04:01 PM
Steve20's Avatar
Steve20
I've used the AMS Synchromesh 5-30 in the trans and the AMS Severe Gear in the diff-car is a stock 95 and had 55K miles and after using AMS, you wouldn't think it was the same car-great results
I also used AMS Full Synthetic 5-30 in the stock engine and I would not use it again. Way too much valvetrain noise at startup and untuil full warmup. In fact, I have 7 quarts 5-30 motor oil leftover and it is going in the wife's Tahoe-not myC4 or C5Z
Steve
Old Mar 10, 2010 | 05:23 PM
dirtcheap74's Avatar
dirtcheap74
I also switched out all lubes to amsoil in my 96 LT4. It is pricey but you will be amazed at how clean it will stay and how long it will feel like new oil, even after some very hard use, you might even notice a little bit of MPG.
Always used it in off road vehicles in the midwest and never had a problem. Matter of fact, 0w30 amsoil compared to mobile 1 syn after 3000-5000 hard miles was like night and day in our trucks. Mine was nice and clean and did not need changed. His (mobile 1) was a gooey dark brown in color. Hell my old 2000 chevy 327 z71 truck went about 20k miles between changes and even then it still looked good and had plenty of viscosity. I changed the filters every 10k miles, they are rated at 25k miles but I did not mind spending 10 bucks to keep my oil nice and clean!
Make sure you get the amsoil filter and if you can find a magnetic collar off of ebay to slap on your new filter, get it!
Good luck.
Old Mar 11, 2010 | 02:30 AM
BLOCKMAN's Avatar
BLOCKMAN
All my customers use it in all the circle track engines we build and never had an issue so far and using that oil has saved some engines from distruction.
Old Mar 11, 2010 | 07:26 AM
c-4 lhozwalte
sounds like its gonna work for me thanks for all the input.
To does anyone here use amsoil?
