Wiper arm is loose
Then while the arms were parked, I checked for play. The driver is fine, but I noticed I can pull the passenger arm down past the firewall even though the bolts in the cowl are tight. I'm guessing something must have broke in the passenger arm while I was previously adjusting it?
So, does this mean the arm is bad, transmission, or something else that can be replaced?
I'll have to look and see if I can pull that arm off.
Dunno about the chattering, seems strange it would do it while wet. try replacing the blades if they are a year old or more. As soon as mine start that I replace em, new rubber is much better on the nerves.
I tried adjusting more where I had the passenger arm parking half way up the windshield and they still did it.
Before I had the passenger wiper arm touching the driver arm, and no problems.
I'm guessing what could have happened is while adjusting the passenger arm. Maybe I pulled it down before I had the two bolts loosened all the way?
Last I checked, I had the wiper arms in park. The driver side arm was tight, but I could pull the passenger arm down past the firewall, and I didn't notice any movement in the wiper linkage inside the cowl. Does that mean the wiper arm needs replacing? As that passenger arm play is the only thing I can think of as to why now I have chatter and crashing when wet and on high speed no matter where I adjust the wiper arms to. Before I never had any problems.
If I pulled the arm off, could I then tell if the arm is bad? How do you pull the arm off?
So I just unhooked the motor and put Rain X on the glass. No more problems.
I noticed when in park, I could pull the passenger arm down past the firewall, and the linkage inside the cowl didn't move. I believe the arms shouldn't move in park. So, would that be an arm problem or transmission? I think I've read something in the arm can get stripped or broken causing play in the arm.
How do I get the arm off? And would there be any way to tell with the arm off whether or not the play is cause of the arm or transmission?
I'm thinking that passenger arm play is what is causing the chatter and noise. Though it only does it when the windshield is wet. Which I'm guessing the blades hit the water causing the play in the arm to show up. I must have done something to it when I was adjusting the arms as it didn't do this before nor after I adjusted it a few times. It was later on that I noticed the chatter and noise not matter where I adjusted the arms to.
The arm is not the problem since there is a guide key. The arm will not slip and slide around if that is still in place.
Your prolem lies in the linkage underneath. Pull the arms off, take the cowl off, and re-install the arms. You can then see what is going on.
Rain X is the cheap and easy fix.
Kinda sounds like the guide pin may be missing where you have slop. Follow Camino's suggestion of taking the cowl off to check the linkages too.
Good luck!
Good luck!
I pulled the GM blade and put the Trico Exact Fit back on the passenger side. And they quit hitting. I was able to adjust the passenger arm back down to where it is supposed to be and they still didn't hit. And also the noise was down too. They still chatter some, but the main thing I was worried about is them hitting.
So, I guess that means 84-94 GM blades are crap. Since I've already got a 20" Anco Aerovantage blade. I may just move that to the passenger side, and get a 19" Anco Aerovantage blade and put it on the driver side to help prevent them from hitting.
Though, on the Anco Aerovantage, the length on the end that is in the middle of the windshield is the same length on the 19" as the 20". But I hardly use the wipers. Only time is after I take it to an auto car wash. So, I don't think I'm gonna worry about it. I've got them adjusted to where they work fine and don't hit.
Removed the new wiper then removed their blade from it and installed just the blade into my old wiper....threw the rest of their product in the trash....good to go.
Removed the new wiper then removed their blade from it and installed just the blade into my old wiper....threw the rest of their product in the trash....good to go.Next time, you may want to look into getting Trico Exact Fit, or Trico Teflon. They sit lower to the windshield than the Anco Aerovantage, which may keep them more stable. I do believe the Trico Exact Fit are the OEM blades for 84-94. They look pretty much the same to the OEM blades I've seen that some owners still have on their car from the factory.
Removed the new wiper then removed their blade from it and installed just the blade into my old wiper....threw the rest of their product in the trash....good to go.I went just looking for the refills in the first place but they didn't offer any. No big deal - I'm good to go for another year.
I can understand why these things hit. There is alot of slop. I noticed while I was adjusting the blades. That while the driver blade was wiping. One wipe it was an 1" or 1.5" from hitting the trim, then the next wipe it hit the trim, then the next wipe it was 1" from hitting the trim, etc. That may be different depending what blade you use.
Though, I originally had the driver blade set too low. As while it wiped while wet, the clip on the arm would hit the parking ramp every down stroke. So, I barley moved it up, and it was hitting the trim. So, I've got the driver blade where it barely misses hitting the parking ramp, and comes real close to the trim. The rubber may actually touch the trim it is that close. So, I don't think I can adjust that anymore or it will be hitting the parking ramp on down stroke, or hitting more of the trim on the upstroke. But it isn't leaving any marks on the trim, so I figured that is good enough and put everything back together.
I do think it is good to find what brand of blades you like, and stick to them. As I noticed just switching to a different brand, that I had to adjust how they parked.
