96 FE3/Z51 sus.?
Old Mar 10, 2002 | 09:09 PM
Rolla Dunkin's Avatar
Rolla Dunkin
Default 96 FE3/Z51 sus.?
I have a 96 with RPO FE3 sport sus.Z51 handeling package.My ? is on the rear spring spacers,there is 1 thick and 2 thinner ones on each side,when I removed the spring all three were on the bottom,however the GM service manual shows that the FE3 coupe with a yellow id spring should have 1 thick on top and the other 2 on bottom. But I'm not sure if the Z51 changes this and the chart in the book says nothing about Z51 has eneyone else with Z51 had there spring off and if so what did you find? Thank's in advance. :cheers:
