92 Cluster issue and no start
Old Mar 10, 2010 | 10:01 PM
mechguy79's Avatar
mechguy79
Default 92 Cluster issue and no start
Ok, this is my Dad's vette and it hasn't run since May 2009. The car is a 1992 LT1 auto with a rebuilt motor. Last time I drove the car the digital part of the cluster was acting up, blanking out, or showing random information. If you slapped the top of the dash the cluster would work for a few then act up again. I'm pretty sure something is just loose.
The second problem is a no start. I do not hear the fuel pump come on at all, not even when you try to start it for a few seconds.
Does anyone have a good part number for the correct fuel pressue gauge so I can check the fuel rail? We didn't find one here in North Alabama that would work.
Second, I am wondering if the instrument cluster problem and the fuel pump issue could be linked. It is kind of fishy that they both happened around the same time.
Any and all advice is appreciated. I'm just trying to get my Dad's vette running so he can enjoy it. Thanks all.
Old Mar 11, 2010 | 12:24 AM
surfer92's Avatar
surfer92
Check the FP relay's and fuses first.
Then see if you have power going to the pump, if you have dash problems, you might have a VATS isssue.
If you have a spare key, try that.
Any FP gauge will work, the schrader valve is under the fuel injector cover on the passenger side, between the nbr 4 and 6 injectors.
Was dash taken apart?
Check the grounds, when my tranny was rebuilt they did not hook up one of the grounds and I had all kinds of things happen.
There are 2 grounds on the tranny, one is a big ole strap on the drivers side near the oil filter and the other is near the starter.
There are several others, but those are the 2 that ground the engine and tranny.
Send an IM to me w/ your email address and I will send you diagnotic procedures from the factory service manual.
Gook Luck!!
Old Mar 11, 2010 | 04:28 AM
mechguy79's Avatar
mechguy79
Gook Luck!!
Thanks for the offer but he already has one. I am trying to diagnose this long distance. I will be visiting him again late June and will give it a shot. I forgot about VATS. Thanks again.
To 92 Cluster issue and no start
