1994 Running hot/ surging idle issue
Also when it heats up, the idle surges up and down and the engine runs very rough at lower rpms, but seems to smooth out when you accelerate more. As soon as the car starts going down the road, the temperature immediatly goes down back to normal.. 190 - 200 and the engine smoothes out.
I tried cleaning the IAC and throttle body, but that did not help at all. The fans do come on when the temp gets around 230 on the digital guage.. There is no check engine light and I am not sure if any codes are stored in the computer.
It seems as the idle surge has to do with the overheating.. I do hear fans coming on, but I am not sure if there are 1 or 2 fans mounted behind the radiator.. would 1 fan not comimg on cause overheating?
Where should I start with this issue?
When the car isn't moving, there isn't any airflow across the radiator fins. So, the temp will climb until it reaches the "fan on" temp.
I think it varies a little depending on year, but it will be in the 225-230 range (looking at the digital gauge).
It's not that the analog gauge isn't very accurate, but the fact that it's measuring the temperature at a different location.
The gauge also isn't linear, so it's next to impossible to know what temp it's actually reading.
Look at your gauge again, and you will notice a shaded area at the upper end.
260 is the max reading on the gauge, and the gauge needle will just about get to the shaded area when the digital gauge reads in the 228 range.
Look close, and you'll probably notice the needle doesn't actually get into the shaded area.
Also, as enventr mentioned you can turn on the A/C to force the electric cooling fans to run. This is one car that will actually run cooler with the A/C on.
Any ideas on the surging and running rough after the car is warmed up?
As said, I cleaned the IAC and the throttle body, but that didnt help.
There is no check engine light and I dont want to start throwing parts at it..
The primary (left) fan comes on (and stays on) with the A/C always. Or, if the A/C is not on, the fan will come on at 228*. If the temp gets down to 218* the fan will cycle off.
(Do this check, just look at it)
The secondary (right) fan comes on at 239*.
If the fans are not running at all the temperature will climb very quickly to the 228 mark. But when the primary fan comes on the temperature should not keep climbing especial this time of year when it is relatively cool outside (<80*).
If I get into traffic, I make sure the A/C is on and that way the primary fan runs and keeps the temperature usually under 215* but usually stays lower.
If you have both fans running at 239* it should definitely keep the temperatures lower than your indicated temps you have.
IF you fan operation is normal, than it is possible the thermostat is a little tired, or possible the flow in the radiator is restricted (lowering its efficiently with less air across it). It may need a cleaning or replacement. You should do a basic flush and change the coolant at least every 2 years.
**So far you have not verified anything for sure. If you have no fans running, dam sure it's going to overheat. But when running down the road you say it's OK so on the surface it sounds like the fans are not coming on.
I would get the temperature problem under control first and then see if the roughness problem is still there.
As said the 2 fans come on at different temps, 226 & 235 (on a 92) and probably what pc said for a 94.
Since it cools down when you get out of the traffic, it's OK.
If it's over 70* out, you can easily hit 207* sitting at 1 redlight.
As said, you can turn on the a/c. You can also install a manual switch easily (but I don't use mine until I hit 220* with more stop lights ahead).
As far as the analog gauge, best bet is to quit lookin' at it, not trying to be funny, most of those gauges do what your describing. I don't look at mine and I've checked the digtal, it is very accurate.
If your coolant's older than 2-3 years, the system needs it's regular maintainence - flush, including pulling the knock sensors.
You need to pull the codes before you even think about addressing the idle problem. Then follow the "rough idle/stumbles" chart in the FSM
IF you're going to keep the car, you need an FSM, you can't diagnois many problems on a C4 without one.
It has to be one or the other or something is not working correctly. The 94 uses one relay for each fan. The 95-96 uses 3 relays consisting of a series or parallel circuit configuration to run the fans in series or parallel with each other. They either run at half speed in the series configuration or full speed in the parallel configuration.
I know that models at the end of the year can have slight differences. But considering of what the PCM has to do to operate the fans, it's got to be one or the other. I don’t think there is a gray area here.
I can tell you what I described is how my 94 car works, as well as what is in the FSM as well as the Haynes manual also. As well as the consensus of many others.
If there is something else out there I would like to know.
The cooling fans should come "ON" anytime A/C syatem is operating.
But, I've know the FSM to be wrong in a few places.
And, IIRC, I only get one fan with the A/C on but I'll verify this as soon as I get the oil pan gasket in and can crank it up.
However in this case the secondary fan is does cycle on and off so it would appear the relay is working. But according to your description, it is doing it at the wrong times. Since the relay is being driven by the PCM it would appear the PCM would be at fault.
You can actually measure the low side of the relay COIL and see when the PCM pulls that point to ground. In the un-energized condition it will measure about 12 volts, and when energized will measure near 0 volts (somewhere less that 1.0 volt).
In my 94 FSM it does say fan…..no S, on my diagnostic flow chart.
I believe your correct on this and might be couple more factors also.Don’t want to hyjack this guys thread but some information I discovered relates. Hope he chimes back in with us.
For ever I have been preaching for the 92-94 models the cycle on and off temperatures of the fans. Well I broke out the FSMs to give a hard look at the diagnostic flow chart section. You can also find duplicated information in other areas of the books but so far I could only find it in that section. I also looked in the VIN J section as well as P. I thought all temps were 10* higher from the FSM, so I quote.
FSM
Primary (left) fan on…..216*, cycle off 208*
Secondary (right) fan on 228*, cycle off 217*
Haynes Manual:
Primary (left) fan on…..226*
Secondary (right) fan on 235*
I have been saying;
Primary (left) fan on…..228*, cycle off 218*
Secondary (right) fan on 238*, cycle off 229*
So I went out and did a test on my 94 vette. With no A/C on, the primary fan came on at 228* like clockwork. Did not come on at 219. So I am sticking with my story as to what I have been saying for years even though it is contrary to the FSM………
I did not let the sucker get up to 239* for the second fan, I was happy at this point.
The programming in the PCM does cycle the fans on if the sensor goes out of resistive range. It might open or short also. But this would show up on the digital display as a wacko temperature which it does not. It is within range although accuracy is not verified. It would also probably throw code 14 or 15 with a MEL light.
for the idle issue this is what fixed mine
check the voltage on the wires from the coil to the opti wiggle them at both ends the pig tail get loose at the plug going into the opti and sometimes needs to be replaced. 2nd check and recheck all spark plug wires
I replaced mine and not thinking I put the new plugs in and the coil plug which is hard to get on the top of the opti I used a pair of long nose pliers and it made a small cut in the plug wire that I couldnt see until one night I listened to the car and I could hear a low popping noise from under the hood I looked and seen a spark replaced the wries a second time and it was fixed.
I doubt any of this has anything to do with a poor running engine and I'd suspect the injectors (check resistance hot/cold) or ignition (Check Engine Light on?) or maybe even a cracked PCM board (aim a hair dryer at it when it's cold).
