LT4 6 speed
Old Mar 11, 2010 | 03:43 AM
Pizzano's Avatar
Pizzano
Default LT4 6 speed
Hello folks , just wondering what MPH you guys cruise in 5th & 6th gear,I have a DRM Modded LT4, 3:45 gears, and it seems sluggish at 100-110 in 6th gear still, am I to expect normal highway cruising should be done in 4th & 5th and 6th for top speed cruises.above 130mph range, or should I go by the RPM to determine what gear to use.
Damn I luv this car!!!!!
Old Mar 11, 2010 | 04:17 PM
Toy90's Avatar
Toy90
Your question is confusing to me. I thought people cruise at 60 to 80mph depending on the speed limit using 6th gear which isn't powerful but with the cruise on it doesn't matter as it's an overdrive. I race on a track at 100 to 110 in the top of 3rd or in 4th and have plenty of power. Top speed will not be in 6th gear but in 5th. If you are cruising over 100 I would be in 5th as 6th is geared really tall and is said to be weak as well.
Old Mar 11, 2010 | 08:08 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
6th gear wasn't meant for "power" runs. It's an overdrive meant to allow very low rpm cruising for the best fuel economy.
At 70 mph, mine runs approx. 1800 rpm.
It will run down the interstate at that rpm all day long, and get 30-32 mpg doing it.
The engine has enough torque to make easy passes and go up grades, but if you need to make a spirited pass you can downshift.
Usually going down to 5th is all that's needed, but if you want to accelerate full throttle you should downshift even lower.
Old Mar 11, 2010 | 08:43 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Mar 11, 2010 | 10:34 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
It's rare I ever use 6th, even at 70. Seems I'm turning about 22-2300 in 5th at 70 mph. I guess if ever found myself cruising any faster, 80+, 6th would come into play.
Agree,..love this car!
BTW, how fast will a stock LT-4 go? 140?
Old Mar 11, 2010 | 11:16 PM
RollaMo-LT4
It will go faster than that.
But as mentioned earlier, top speed is achieved in 5th
Old Mar 12, 2010 | 07:28 AM
Leec4ce's Avatar
Leec4ce
Couldn't say it any better and welcome to the LT4 family. Spend some time getting to know your car, take some driving lesions
get some track time and you should be able to get more than 140 out of her.
Old Mar 13, 2010 | 01:17 AM
mnstrlt1's Avatar
mnstrlt1
when do you get an opportunity to go 140+mph (or even 120+mph) for any extended period of time? I get nervous doing 80+mpg (with the number of cops around).
Of course, I also use 6th gear around town at 40+mph (at least it's practical in the wide open/flat stretches of roads in Az).
Old Mar 13, 2010 | 05:44 PM
Leec4ce's Avatar
Leec4ce
At a track not on the highway
Old Mar 13, 2010 | 06:53 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default original owner LT4
Its your car, the owners manual mentions 6th gear is for 60+ when driving. Below 60 say the speed limit is 55 I use 5th. I do not want any tickets and was stopped for 61 in a 55 once. Was so happy to just get a warning.
To LT4 6 speed
