Cutouts installed...........
Old Mar 10, 2010 | 04:18 PM
Weav's Vet's Avatar
Weav's Vet
Default Cutouts installed...........
Also wanted to say I'm really going to like the 3.45 gears in the Dana 44. Can't wait to get it to the track.
The cutouts are from DMH.
The exhaust system is Stainless Works LT's into bullet cats into the stock pipes with the resonator removed and in it's place a X pipe from RacerX70CC. Stock mufflers and tips.
I like it!
Here's a few still shots
It takes the video about 15 seconds to get going.
Old Mar 10, 2010 | 04:23 PM
CAJUN C4's Avatar
CAJUN C4
Sounds Good...What is all that hanging underneath the car?
Old Mar 10, 2010 | 04:26 PM
Weav's Vet's Avatar
Weav's Vet
The wires? That's for the controls. You can't see them when it's sitting flat. I had to give them a length for the wire and I guess I over estimated a little.
Old Mar 10, 2010 | 04:28 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Sounds very good! I have a similar setup (LTs, 3" cats, X pipe, stock LT1 mufflers) only Im too poor for electronic cutouts. I have to crawl under the car and unbolt a plat for the car to be loud. Maybe someday Ill get the electronic ones.
Old Mar 10, 2010 | 04:30 PM
Weav's Vet's Avatar
Weav's Vet
Nothing wrong with that. I'm just lazy. I like your Bowtie
Actually, you gave me the idea to put mine where I did. Kind of tight everywhere else.
Old Mar 10, 2010 | 05:08 PM
nutz4c4's Avatar
nutz4c4
Old Mar 10, 2010 | 06:06 PM
Kubs's Avatar
Kubs
Glad my work inspired someone! It is tight under there. The bowtie looks less like a bowtie from hitting the road a couple times.
Old Mar 11, 2010 | 12:09 AM
dogfish246's Avatar
dogfish246
Thats really great! Nice work! I think I will follow an buy some cutouts!
Here comes the questions!
Are you satisfied with the cutouts and quality?
Do you think they can fit right next to the muffler and face towards the outside of the car (towards the back of the wheel) or are they bulky?
How did you install the electricals? Where did you get your power and place your ground?
Where did you run your open/close switch to get it inside the car?
Thanks! Thats real nice!
Old Mar 11, 2010 | 12:44 AM
mnstrlt1's Avatar
mnstrlt1
My impression of cutouts was to have them installed directly behind the headers? Was the objective here just for sound?
Actually- I'm just impressed with how clean the c4 looks! the mufflers cleaned up really nice with what appears to be a coating of black on them! Looks awesome!
Old Mar 11, 2010 | 05:15 AM
Weav's Vet's Avatar
Weav's Vet
Thanks!
The quality is first class! Very well made.
You might get them in there where you stated. TBH I didn't really look at that particular spot. With the motor it is a little bulky and it can't touch anything.
I hooked it to the cigarette lighter. The ground went to a bolt under the shifter. I drilled a hole just the right of the shifter to run the wire through and used a rubber grommet to seal it off.
Old Mar 11, 2010 | 05:36 AM
Weav's Vet's Avatar
Weav's Vet
And your impression is correct. I wished I could have put them at the headers. With cats and the A4 there just isn't room to do that without losing ground clearance. With a lowered car that is out also.
Objective.......well, I had Corsa on there and with headers and also with a mid range cam it had become louder than I wanted, especially around town. With the motor stock the Corsa was perfect for me. This setup sounds good though. I really like it! It screams at WOT and is pleasant any other time with just a low growl.
Sound wasn't really a thought. It sounds like a truck with a missing muffler now when they are open all the way. I'm sure closer to the headers would have had a richer tone. I had read I may lose about 15 hp or so going back to the stock cans from the Corsa so I figured I'd use these to hopefully gain some back when I went to the strip. I worked hard to get the 345 rwhp I have now and didn't want to lose any of it. I'll find out in about a week when I go back to the dyno I've been using. The the next T&T is April 3rd. I also kind of like the look of them. Something a little different. This will be the first track time for the Dana 44 too. Maybe I'll knock another tenth off. Best yet was a 12.3 @110. That was with the 3.07 gears.
Thanks for noticing, it's really kind of dirty under there now. You can see my greasy finger prints on the half shafts. I'll take care of that though.
Old Mar 11, 2010 | 07:56 AM
Kubs's Avatar
Kubs
Actually its just for sound wherever you put them. Most people try to put them after the headers because a car with factory cats is quieter than the high flow versions the OP is using. Putting them after the cat in this case still makes the car loud.
Old Mar 11, 2010 | 11:19 AM
engle1147's Avatar
engle1147
Old Mar 11, 2010 | 11:46 AM
A1990's Avatar
A1990
very similar to my QTP's. Yours are very nice.
Old Mar 11, 2010 | 12:22 PM
Weav's Vet's Avatar
Weav's Vet
Yup, very loud!!! It'll rattle your brain inside the car.
Old Mar 11, 2010 | 12:24 PM
Weav's Vet's Avatar
Weav's Vet
Thank you!
How are yours holding up? I almost bought QTP's but went with these because of the warranty. I really liked the remote option feature of them. Do you have that?
Old Mar 11, 2010 | 01:45 PM
A1990's Avatar
A1990
Yes, I purchased the remote. mounted in the console.
To Cutouts installed...........
Old Mar 12, 2010 | 08:39 AM
jmrl98's Avatar
jmrl98
Good stuff weav - you've got some deep pockets bro'. Obama asking you to help bail out the gov't?
Old Mar 12, 2010 | 09:53 AM
twin540's Avatar
twin540
Were did you get them? NICE. Thats what I hate about this forum you guys infect me with crazy thoughts.
Old Mar 12, 2010 | 11:08 AM
reoch999's Avatar
reoch999
Hey, that's a great idea to put them there. Why didn't I think of that?
12.3 is movin' pretty good. Do you know what the DA was? It'll be interesting to see if the dyno numbers change much. I'm interested in what those cutouts do. Aside from improved sound, I've heard some say they make little to no performance difference, some say they help, some say they hurt. My personal thought is they would probably hurt low end torque on a stock motor, but with mods like yours I suspect they may help the higher RPM hp more than they hurt low tq, especially since you're stalling past the low RPM range anyway.
I've been following your project for quite a while now, I'm almost as excited for yours as I am for my own! We've had a few nice days here this week and like you I'm looking forward to test & tune days in April.
