Temps slowly creep up on freeway.......
but I cannot find a issue in the forums specific to what I am seeing on my c4.I purchased a 1996 LT4 6 speed Coupe about a few weeks ago. It seems to run pretty good overall. Has all service records back to 1997. Had a waterpump fail in 2006. Overheated the engine. Chevy dealer put in new WP, new opti, and a new radiator.
When I bought it the owner told me it runs hot, but that it was normal to hit 230 in traffic, which I had read about here. I had already been reading these forums for quite a while and felt I had a good idea of where it should run.
The car basically slowly heats up at moderate freeway speeds (55-65). It has been nice and cool in SoCal the last few weeks, with temps in the high 50's at night and mid 60's during the day. The temp on the car while Im in 6th gear slowly climbs it seems to 219. It then stabalizes as the fans low speed kicks on.
This does not seem normal in very cool weather. I drained the coolent out, was going to change t-stat to 160 but decided to put the 180 back in. Replaced the belt and hoses. Changed oil to Amsoil 0w30 and filled the cooling system with dextron (orange) and mineral water.
Started the car, got it to operating temps (above 180), turned it off, let it cool down, filled it with more water, started the car again, got it above 180 again and then filled it with water again, not as much this time. The third time I got it warmed up and cooled down it did not really need much water but I added to the overflow tank and now it seems to be just about right.
I have read on here where the LT4 has ONE bleeder valve on the t-stat housing, which is easy to find. I have not bled it tho as it feels a little to loose for my taste, possibly stripped out by previos owner? When it starts to loosen up (with the car over 200 degrees, under pressure, but engine off) It feels like it will just pop clear out. I also see what looks like plumbers tape around the treads. Does any of this sound normal? should it feel like it is going to come clean out of the t-stat housing? Should I be seeing plumbers tape around the upper portion of the bleed screw?
So I get on the highway and it heats up gradually to 219 unless I either downshift to 5th gear or get off the highway and hit surface streets, (not in traffic)which really does not make sense. Why would the car cool better at 35-45 mph than at 55-65mph?
Last but not least I do seem to smell a faint trace of coolent after driving it around town and after it has got up to 230-240ish. It always seems to have a very faint coolent smell to it. I know when cars get hot they can release into overfill tank but should I always be smelling coolent?
Thanks for any help.
Edit: Oh and I had someone tell me it might have a possible head gasket leak, I do not see any white smoke when I drive the car but it is hard to see back there when driving. I have been debating the idea of adding fine nanoparticle sealer to the cooling system to possibly shore up any cracks or leaks. Any thoughts on this stuff?
Have you pulled the radiator and cleaned out the trash in there?
Smell the exhaust once its warm and idling see if you smell the coolant from there. Pop the raidiator cap off and then do a bleed down test on the cyls.
I couldnt stand the high temps they run at, drove a 93 with all new everything for a few months. There is no reason in my mind why a car should run that damn hot unless its strictly for emiisions;It drove me crazy
Just doesnt leave much room for error, doesnt leave much time to catch it if it creeps up to 240, 250 or more while driving and the temp gauge is already pegged.
Either your not getting coolant flowing properly through the radiator, or your not getting enough airflow through the fins.
At any speed above 40 mph, your coolant temperature should not be going over 195 - 198
Lay on your back under the nose of your car, and look up into the radiator cavity. These things will suck up all kinds of trash and block the fins.
Also check the area between the radiator and the condenser, and that can also block airflow.
Added: That 230 temp is normal while at extended stops, but not at highway speeds.
Does not seem like anyway to powerwash the rad without fulling pulling it out which is a bummer.
Given your info, I would look at a minor head gasket failure. Not enough to cause major overboiling - but enough so that its heating up the coolant more than is normal. A very minor head gasket issue can cause upward creeping temperatures, without giving much of the normal indicators of exhaust gas in the cooling system etc.
Thomas
makes me think they put the wrong one in.
also the system needs to be burped properly.
I had a fan die on my car
on the highway it was fine, the second I hit of off ramp WAMOO
I do need a new air deflector and fans to get it back to running 180 - 190 (my main fan is programmed for 190)
When filling up the system, cold,crack the bleeder. Then warm up the car until the Tstat opens and bleed it again.
This does sound like an "air in the system" problem.
Next time you flush, pull the knock sensors. There's a lot of crud in there that doesn't come out by just draining the system.
What I would do is replace the radiator cap, drain/flush coolant and replace the thermostat with an OEM unit as it takes a certain thermostat. It would probably be good to drain the coolant from the drain plugs in the block to make sure there isn't crud sitting in there.
Oh, and what does the coolant color look like? 96's have dexcool. It is possible they used the wrong coolant in the past and it has sludged up.
I had one that was tired and as I drove it kept getting hotter and hotter. In a pan of water I could see it was not opening up enough.
Do the simple things first. Replace it with a LT1 stat as indicated above.
There are 2 air bleed valves.
