Please help with a No Start Problem
Old Mar 13, 2010 | 12:04 PM
jmeyer58's Avatar
jmeyer58
Default Please help with a No Start Problem
Hi all, I have been searching the forum and unable to come up with an answer that relates to my problem. I have a '93 LT1 6 spd that sat all winter.
When I tried to jump it to get it out of the garage it would not start or crank.
My first thought is VATS but the security light was not lit -not flashing or lit up (clue 1).
Also, the speedo is not operational at all (clue 2). The tach and analog gauges all seem to work but the digital display portion is dead in the water.
I tried to jump the ALDL terminals to get into the diagnostics but nothing comes up on the display (clue 3).
I have checked all the fuses but I am wondering if I missed something. Has anyone experienced this and do you have a fix or something else I should check?
Thanks!
Old Mar 13, 2010 | 12:10 PM
engle1147's Avatar
engle1147
Low battery voltage will do strange things to a car.
Check/clean the battery terminal....charge the battery....load test the battery....replace the battery if it will not take a charge or fails a load test after fully charged. Most autoparts stores will charge and load test a battery free of cost.....if you remove it from the car and take it to the store.
Old Mar 13, 2010 | 12:44 PM
jmeyer58's Avatar
jmeyer58
Thanks for the quick reply, I forgot to put in the original message that the battery is back to normal voltage and the connections have been cleaned and tightened. I am getting nervous that I may need a CCM so I am looking for other posibilities.
Old Mar 13, 2010 | 01:14 PM
desertmike1's Avatar
desertmike1
Get into your FSM, and search out the various grounding points supporting the dash mounted electronics, CCM ect. One of these may have some corrosion that formed over the winter.
Old Mar 13, 2010 | 01:21 PM
engle1147's Avatar
engle1147
I'd load test the battery anyway.
Old Mar 13, 2010 | 01:25 PM
86Pacecar's Avatar
86Pacecar
I agree, a bad battery can still show normal voltage but fall flat when put under a load. This can also cause the car to not take a jump start.
Old Mar 13, 2010 | 01:35 PM
desertmike1
you bet...this should be the first step.
Old Mar 13, 2010 | 03:39 PM
jmeyer58's Avatar
jmeyer58
I have eliminated the battery because with the key on engine off the speedo is blank and the security light does not come on yet I have 12.5 volts at the battery and the other warning lights are working normally. The grounds are something I haven't checked yet so I think I'll go down that road next. Anything else I should for? Thanks again to everyone so far for their help.
Old Mar 13, 2010 | 04:56 PM
desertmike1
Other then checking connections, I'm pretty much at a lost, I think your heading down a good path.
When you checked the fuse's, did you use a meter, or just a visual inspection. Also did you look closely at the "fuse" blade connections...both male and female (side) for possable corrosion.
If I had this problem I would Definitely verify both power, and ground circuits.
Old Mar 13, 2010 | 05:11 PM
jmeyer58's Avatar
jmeyer58
The connectors are next after I check the grounds. I used a test light on the back of the fuses to check for power, all tested good. If it's not a ground issue, I'll have to pull the fuses one at a time and check for corrosion on the blades and in the slots (very time consuming and a pain in the ****) and check the connection at the CCM and I think I saw a connector in the wiring diagram between the cluster and the CCM that I'll have to check. Thanks again for the suggestions.
To Please help with a No Start Problem
