Which injector to go with?
Old Mar 11, 2002 | 12:36 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Which injector to go with?
I've got my car in the shop and they are leaning towards injectors for my rough idle... if indeed this is it, which injectors to go with for my 95 LT-1?
It looks like FMS or accel would be the way to go... but on Jegs application guide for the accel on the stock Lt-1, they list a 26lbs injector for a 95? :confused:
I just want to drop in replacemnt injectors and no need to reprogram anything. Anyone have any advice on this?
Thxs
Old Mar 11, 2002 | 01:06 PM
Dragon2U's Avatar
Dragon2U
Default Re: Which injector to go with? (Springer's 95)
I've looked for the same thing and you're right, Jegs says 26 for a 24 car. Not sure why. There are #24's available from them, might have to call and ask why the difference. I doubt that you would run into problems putting the 26's in there but maybe someone that did this could shed some light.
If you go with FMS, some do the #19 or 24's. I've heard the 24 might be better to go with, they probably flow more like 26's in our application due to the larger fuel pressure used in the Vette. Maybe that's why Jegs uses the 26 for us????? It all depends on pressure setting, flow rates, etc.... but I think + or - 2 isn't going to bother the motor enough to warrant a change.
:seeya
Old Mar 11, 2002 | 01:41 PM
Springer's LT4
Default Re: Which injector to go with? (Dragon2U)
Cool..thanks for the info. The shop did a load balance on the injectors and they say their fine. Problem is so small that nothing is picking it up. :(
Old Mar 11, 2002 | 02:54 PM
GlockLT4's Avatar
GlockLT4
F*rd Motor Sports, definitely. Don't buy GM replacements, $800+ is ridiculous!!! I use the FMS 30# and they are working great!
To Which injector to go with?
