Front Spring Removal for Lowering Project
Old Mar 14, 2010 | 01:56 PM
cumbercr's Avatar
cumbercr
Default Front Spring Removal for Lowering Project
I've been looking into installing a lowering kit. I've seen threads regarding replacement of the wedges, etc. Where I'm stuck is how to get the front spring out. The FSM says you need a special spring compression tool that I obviously don't have. How have you guys done it?
Old Mar 14, 2010 | 03:57 PM
Weav's Vet's Avatar
Weav's Vet
First off, get the front of the car as high as you can, you'll need to do that for the spring to be removed. You'll have to remove the lower control arm on one side. Use a floor jack to hold the spring pressure while you remove the lower ball joint then the control arm. Swing the hub out of the way and support it on something like a 5 gal bucket. Remove the brackets that hold the spring in place in the center. Then you can slide the spring out. You'll have to wiggle and twist it a lot to remove it.
Old Mar 14, 2010 | 04:45 PM
Weav's Vet's Avatar
Weav's Vet
In this link there is the best write up on C4 lowering. It's been on here several times.The 4th link down from the top. Maybe you've seen it already. I'd post it here but it's a Microsoft Word DOC file and I don't know how to do that and get the pictures in there. Perhaps someone else will know.
http://www.google.com/search?client=...=Google+Search
Old Mar 14, 2010 | 04:54 PM
cumbercr's Avatar
cumbercr
Thanks guys. That's exactly what I was looking for.
I might have to try this. Looks like as long as I'm in there new ball joints and tie rods would be a good idea.
Old Mar 14, 2010 | 07:06 PM
in-vette-uation's Avatar
in-vette-uation
one other note: you don't actually have to remove the spring, you can slide it out part ways on each side to access the wedges. That means you don't have to get the car so high in the air. Worked for me.
Old Mar 14, 2010 | 08:42 PM
cumbercr's Avatar
cumbercr
Thanks. I'll see if that works before pulling it out. Mine is a Z51, so the spring is supposed to be a little easier to get out (not as much curve).
Old Mar 15, 2010 | 10:04 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
That's Kevin's(Central Coaster) write up. He has updated it since, you may want to check it out. http://webpages.charter.net/khasting.../lowering.html
Kevin was a great help, when I lowered mine.
Old Mar 15, 2010 | 11:43 PM
96GS#007's Avatar
96GS#007
Jack one side of the car higher than the other. Then you don't need the car sky high to remove the spring.
Old Mar 16, 2010 | 09:43 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
details?
the reason I wanted a shop to do it, is that I wanted them to use a lift.
but it's taking FOREVER to get it in there
all the parts are here, I want to get my coilovers on.
Old Mar 16, 2010 | 04:10 PM
Turbogtu's Avatar
Turbogtu
Don't have to remove the lower control arm it will swing down out of the way, although it will probably take some force the first time, mine did. You shouldn't have much trouble at all with a z51 spring, not much curve to it at all. Probably will have to remove it though to do a good job removing the stock rubber and putting the new on. I recommend removing the rubber on the ends as well. You'll probably spend more time removing the old rubber and gluing on the new than you do removing and reinstalling the spring.
Old Mar 16, 2010 | 10:18 PM
96GS#007's Avatar
96GS#007
Originally Posted by BrianCunningham
details?
Not much in the way of details. Just jack one side of the car about 6" higher than the other side. On mine, I'd guess that the drivers side was ~12" in the air and the passenger side was ~18". The base suspension 1996 springs have the most curvature of any yeat and I was able to remove mine without issue...and replace with with a '90 Z51 spring from Hyperco
For the rear, no need to do anything fancy. Remove a bolts and it falls right off.
Old Mar 16, 2010 | 10:37 PM
cumbercr's Avatar
cumbercr
Thanks 86. This is why I love the forum. You don't get these tricks out of a shop manual. What did you use to glue the wedges to the spring? I'm thinking 3M weatherstrip adhesive.
Old Mar 17, 2010 | 11:32 AM
Turbogtu's Avatar
Turbogtu
I used two part epoxy, "plastic weld" i think, from autozone.
Old Mar 18, 2010 | 03:59 PM
LannyL81's Avatar
LannyL81
Are the metal brackets that are around the rubber pieces that are cut-off....are they reused with the wedges?
Old Mar 18, 2010 | 05:23 PM
cumbercr's Avatar
cumbercr
The later years (88-Up) reuse the aluminum brackets. They can be trimmed to match the height of the new wedge. The early models have steel brackets that need to be replaced.
Old Mar 18, 2010 | 11:10 PM
Turbogtu's Avatar
Turbogtu
negative ghost rider.....just toss em
the ones cumbercr is talking about are the support brackets that bolt on around the wedges.
if I was to move out to az.....does she have a friend for me?
To Front Spring Removal for Lowering Project
