DMF movement specs
Old Mar 14, 2010 | 04:03 PM
pelensky's Avatar
pelensky
Default DMF movement specs
I just got a used DMF. It has total rotation of about 3/4" pushing it as hard as possible by hand. It also has a very slight tic toc (rock back and forth but only about .003". Does this sound okay?
Old Mar 14, 2010 | 04:05 PM
pelensky's Avatar
pelensky
One more thing. My old DMF had machine grooves from the factory that started in the center and went outward toward the circumference in an angular pattern. The used one I got has radial grooves. Did any DMFs come with radial grooves from the factory or is this a sign that it was turned? I was told by the seller that it was not turned and it still has a little step down toward the hub similar to my old one with the different machine grooves.
Old Mar 14, 2010 | 06:38 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Two of the MOST relevant threads on specs, slop, and swapping DMFs:
http://forums.corvetteforum.com/c4-t...l-article.html
http://forums.corvetteforum.com/c4-t...orvette-2.html
Here's my sentence in bold...."Does anyone put anything relevant in their profile?"
To DMF movement specs
