17 inch wheels on an 87?
Old Mar 15, 2010 | 04:00 PM
blacklight's Avatar
blacklight
Default 17 inch wheels on an 87?
Went to get new tires for my 87 and perhaps a little wider than stock 255/50V16. Problem is not many of them are made. so the question comes down to 17 inch wheels, I have extras from my 89, but will 285/40 17 or 275 wheels fit on an 87? Someone outthere must know. I have heard something about needing an offset of some kind. Can you helpme?
Old Mar 15, 2010 | 04:04 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
To use the wheels from the '89 you need a .75" adapter/spacer. Other than that a 285/40/17 tire will fit fine on your car.
Old Mar 15, 2010 | 04:24 PM
blacklight's Avatar
blacklight
Default 17inch wheels on an 89
Hey that is great. Just talked to my mechanic and he agreed. said the spacer runs about $250. Sound about right to you?
Old Mar 15, 2010 | 04:25 PM
blacklight's Avatar
blacklight
Default 17inch wheels on an 87
Old Mar 15, 2010 | 06:27 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
You don`t want spacers. You want concentric wheel adapters like these---->
They only cost around $50.00 for a pair on FleaBay
I put `96 sawblades on my `87 with them.
Old Mar 16, 2010 | 09:33 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
As you shop, pay attention to the terminology the company is using.
A spacer can look like the above pic also, and is what you want. The difference between spacer and adapter is usually the bolt pattern.
A spacer will have the the same bolt pattern (the recessed portions for the lugs and the studs) and an adapter will bolt on to your hub and then allow a different bolt pattern wheel to be used.
Old Mar 16, 2010 | 10:27 AM
GlennS87's Avatar
GlennS87
I have ZR1 repros 17x9? & 17x11 with the correct offset. I got mine from AFS but I know there are plenty of places to get them.
Old Mar 16, 2010 | 11:04 AM
Joe C's Avatar
Joe C
same here, but i put 9.5's all the way around, on my 85. i bought AFS silver finished ZR-1 repro's, off ebay several years ago, for around $400. i perfer to use direct fit wheels vs. adapters (or spacers) - one set of lugnuts per wheel is enough!
Old Mar 16, 2010 | 12:17 PM
c4cruiser's Avatar
c4cruiser
I have two sets of AFS wheels for my 87. One set for my Hoosier A6's and the other for street and track days.
AFS sells on flea-bay and they usually have sets of ZR-1 style wheels with the proper 38mm offset so no adapters are needed. They will have wheels only or wheel and tire combinations that are already mounted and balanced. Just bolt 'em on and go.
Now for the strange part: If you look at a 255/50-16 tire mounted on a '87 16x9.5": wheel and at a 275/40-17 tire mounted on a 17x9.5" wheel, they will be appear to be very close to the same in terms of overall diameter and tread width. That means that the speedo is not going to be too far off at all and the 17" tire/wheel combination will easily fit in the wheel well and not have any issues with clearance.
A 285/40 tire will also fit on the 17x9.5" wheel with no problem (93-96 C4's with the base suspension had that tire size in back), but the diameter will be greater so you will see some difference in the speedo readout. They will also fit in the wheel wells with no clearance issues.
Old Mar 16, 2010 | 07:42 PM
project C4's Avatar
project C4
17 x 10.5 no spacers or adapters.
http://forums.corvetteforum.com/c4-g...-handbook.html
Old Mar 16, 2010 | 08:01 PM
kenv's Avatar
kenv
St. Jude Donor '10
THIS is what most companies will sell you as "Spacers" You do not want these!
Old Mar 17, 2010 | 11:48 PM
kawijames's Avatar
kawijames
no spacers or offsets w/56mm offset, 275/40/17 all around. search on my name you'll see them on the car. I currently have 17x9.5 Z06 replicas.
Old Mar 18, 2010 | 10:06 AM
Kubs's Avatar
Kubs
Originally Posted by project C4
To 17 inch wheels on an 87?
