Poly Control Arm Bushing Install Questions
Old Mar 15, 2010 | 05:21 PM
eguyett1985's Avatar
eguyett1985
Default Poly Control Arm Bushing Install Questions
I'm finally done with the installation portion of the ES poly bushing install on a set of 87 control arms and fighting with pressing the upper 1pc bushing in for over an hour Even with an extra set of hands I could not get the lip on the leading edge of the bushing to compress straight into the bore and keep everything lined up...#$&*%....I think it's nearly impossible to do that without making a tapered install tool and a driver, which I did and then I had them together in no time at all. Now that I have them in and the arms put together I get to the nuts on the upper shaft and after seeing torque values ranging from 10ft lbs to 80ft lbs, I snugged them up by hand just to the point where there is a slight bind on the bushing but it still moves freely with the control arm and washer but the nut does not move, this seems like somewhere in the neighborhood of 25 to 30 ft lbs. Is this the norm? I called Energy and the tech guy said "Sounds about right". Here's what I ended up making:
Old Mar 15, 2010 | 06:17 PM
rodj's Avatar
rodj
I can see a nice little market for you out there to take the pain out of the install.
Not having your facilities I filed the lip off to get it started square
Old Mar 15, 2010 | 06:21 PM
LBYRNES's Avatar
LBYRNES
I've been battling four poly bushings for 5 days now and I would have gladly purchased a tool to do this.
Of course, I don't have a press either.
Old Mar 15, 2010 | 06:23 PM
eguyett1985
Man I feel for you!
Old Mar 15, 2010 | 08:12 PM
Elrick's Avatar
Elrick
I recently posted the upper a arms bushings for sale because I could not figure it out. 2 different garages said they couldn't guarantee that they would not crack the aluminum arm and one of the garages was a "corvette specialist" I think you have a little business brewing. I will sign up as first customer
Old Mar 16, 2010 | 01:29 AM
eguyett1985
Apparently I'm not the only one who's had a problem with this. I'll see what I can do about making a few more sets.
Old Mar 16, 2010 | 07:35 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
i had the same problem and you know what i did?i let the sob start crooked and you know what happened it went right in.i used nothing but a bench vice to install and remove all bushings,except the stock bushing in the upper control arm that rests next to the big washer.it HAS to be pressed out.everything else can be done in a big vice.easily and quickly.
Old Mar 16, 2010 | 12:29 PM
TJM's Avatar
TJM
Ball Joint C Clamp works well too [ Advanced Auto parts hasfree loaners].
Works like a charm if you have an air wrench not bad if you have a breaker bar. Here the large vice is a big help too.
Upper A arms are another story. Press is the best tool BUT be sure you have that spacer bar in there.
You'll be shocked how easy it is to deform an upper A arm.
And don't heat anything!
TJM
To Poly Control Arm Bushing Install Questions
