EGR delete on 85?
Old Mar 19, 2010 | 03:08 PM
1985 quick silver's Avatar
1985 quick silver
Default EGR delete on 85?
Ok, so I relly wanna get rid of the egr valve. Thier almost $70 to replace(wich I will have to do unless) plus I would have to get the new temp sensor for it, and its kinda a pain in the butt to get one ( A 45min drive and $16) so if i can get rid of it that would nearly save $100 bucks. So my question is has anyone had any problems with the delete or any real performance loss?
Old Mar 19, 2010 | 04:40 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
The problem you might have is pinging. If you use 91 octane you should be OK.
Old Mar 19, 2010 | 05:09 PM
1985 quick silver
No engine lights or any thing?
Old Mar 19, 2010 | 06:07 PM
0Paul Ruggeri
Former Vendor
Since the 85 uses a manifold passage and not a seperate pipe to feed exhaust to the EGR, I don't think there's a sensor to detect EGR on an85.
Old Mar 19, 2010 | 06:56 PM
1985 quick silver
The only sensor it has for it is a thermocouple at the base plate on the egr itself.
Old Mar 19, 2010 | 07:57 PM
pletzvet's Avatar
pletzvet
Have you tested the EGR to confirm that it is indeed not working? You asked about "no engine lights or any thing" - if it was throwing a code ... I'm pretty sure the EGR circuit failure is a code 32, but this does not necessarily mean that the EGR itself is kaput. Do you have access to a Helms Shop Manual for this year of car? It sets out the steps to narrow down exactly where the EGR circuit failure is occurring.
My opinion...fix it rather than eliminate it.
Old Mar 19, 2010 | 09:22 PM
redrose's Avatar
redrose
in extended periods of light load engine operation the ecm enters 'highway' mode...failure of egr in this mode will cause the engine operating temp to rise, typically evidenced by some increase in coolant temp...in extreme cases piston damage may occur.
note your engine coolant temp while driving varying throttle positions in the 'countryside', and watch after entering 'turnpike' (constant throttle position)...if coolant temp 'goes to a higher level' the egr is likely malfunctioning.
Old Mar 19, 2010 | 10:39 PM
1985 quick silver
ok, I guess ill just stick to the plan and change it. I got the new valve already, i just need the temp sens, I guess ill go ahead and order it from napa.
Old Mar 20, 2010 | 08:03 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Have fun finding the sensor. They aren't made anymore. This is the part number you need 14087416. New part number is ACDelco 212-337. They can be ordered
Old Mar 20, 2010 | 01:45 PM
klkordzi's Avatar
klkordzi
I deleted my EGR and Air pump on my 85. No codes thrown,
To EGR delete on 85?
