vortech
Old Mar 21, 2010 | 08:37 AM
texasedirpvette'91's Avatar
texasedirpvette'91
Default vortech
Anyone used a centrifugal Vortech sc before? I picked up a V1 for a pretty good price. Was on a 302 stang. Figured I could give it a try. Any input? Or a place I could get the mounting kit? I'd rather not make one.
Old Mar 22, 2010 | 04:05 PM
lisoundsvette's Avatar
lisoundsvette
get in touch with
greg from BLOWERWORKS
201 891 4690
I HAS A C4 BRACKET ASSEMBLY THAT WRAPS THE BELT REAL WELL TO PREVENT BELT SLIPPAGE
HE ALSO HAS EVERYTHING ELSE YOU MAY NEED TO GET THE JOB DONE RIGHT
THE FIRST TIME.
Old Mar 23, 2010 | 10:11 PM
Guitarguy's Avatar
Guitarguy
just bring lots of $$$
Old Mar 24, 2010 | 04:22 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
there's plenty of guys here running them
the head unit doesn't actually cost that much
it's the rest of the kit that adds up.
Old May 2, 2010 | 08:38 PM
94 blackBeast's Avatar
94 blackBeast
Yep have one on mine..and if I'm correct they have vortech has discontinued the kit. At least thats what I was told when I had to order a new fuel pump.
Old May 2, 2010 | 11:46 PM
dizwiz24's Avatar
dizwiz24
I agree 100%, all the surrounding stuff is expensive
dedicated drive bbracket, big injectors and a tune (or the equp. to tune to do it yourself - which is worth learning), methanol injection (if you desire), wideband o2 sensor, aftermarket ECU (if you desire")
I know this doesnt apply to you, but dont ever get any of the shoddy kits put together by the big name supercharger manufacturers.
They are junk. The only good thing in them is the head unit itself.
Also, the FMU's in the kit (that rely on a booster pump to overpressurize your injectors under boost) run too rich, and are known to fail - leaving you with a lean condition that destroys your motor.
Also, you need a dedicated drive belt setup, that use a separate belt to drive your supercharger. This is separate than the belt driving the rest of your accesories. Otherwise you will get belt slip at the crank pulley.
Old May 3, 2010 | 02:48 AM
jak112460's Avatar
jak112460
Not sure on a C4 but on a C5 the blower is facing the motor. On a Mustang it's facing away from the motor. You may not be able to use that head unit as it may rotate the wrong direction for you C4. Vortech makes a very nice blower I had one on my C5. On my completely stock motor with only the Vortch blower setup the car made 510 RWHP. Not too shabby.
Old May 4, 2010 | 01:11 AM
mnstrlt1's Avatar
mnstrlt1
Ls-x engines respond incredibly well to nearly any mod.
With that said, he is right about the head unit being usable in our c4 applications.
Of course, the right person to talk to IS Greg (www.blowerworks.net).
To vortech
