Engine Hood Shock Absorber?
Old Mar 23, 2010 | 05:12 PM
LD85's Avatar
LD85
No problem, my Autozone props are a little tired so I ordered two more of these, they have a 2 year warranty as well!
I also ordered 2 of their Hatch struts!
Old Mar 23, 2010 | 07:56 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by LD85
$69.99 I need ringers lactate
Remember to keep telling yourself "its a hobby"
Old Mar 23, 2010 | 11:18 PM
lgolson's Avatar
lgolson
I've had my 86 for over 6 months now those supports are so worn out I didn't even know they were there! I always thought that the hood was really heavy. I think I'll be replacing mine for sure!
Old Mar 23, 2010 | 11:36 PM
Z51JEFF's Avatar
Z51JEFF
My 91 only had the one long strut-lock but have always known the mounts were there for the short struts,my 84 had these.I put the 2 short struts on the car with a fairly new main strut support,the hood would open so hard I thought the hood was going to break.I removed one of the short struts and it opens fast but still need to hold the hood as it opens to keep it from going forward too hard.
Old Mar 28, 2010 | 02:28 PM
Flame Red's Avatar
Flame Red
$8.50 each
http://www.theautopartsshop.com/sear...ext=S2SG430011
Hood Lift Support Sachs Clutches SG430011
Brand:
Part Number:SG430011
Price :$8.50
Additional Information
Warranty:
Category:Hood Lift Support
Description:Hood Lift Support
Condition:New
Req Qty:2
Note:Picture may be generic, please read description and check fitment notes.
Sorry, this wont work for a 90 or later. Looks like there is some kind of clips needed to make it work.
Only problem is, how does one remove the old post on this bracket. I tired screwing off the bushing and it won't budge. Any ideas how to remove the old posts so bolts can be used to replace them. Looks like I can get all this at Home Despot.
Old Mar 28, 2010 | 04:58 PM
LD85's Avatar
LD85
Got my SACHS brand, they are not as good as th Mighty Lift brand by Autozone's which are $17 each
Get the Mighty Lifts...
Old Mar 28, 2010 | 06:40 PM
86PACER's Avatar
86PACER
$69 a piece is way overpriced.
I got them for $8 a piece from Rock Auto.
Part #SG430011 for pre 89'
Nice improvement in ease of opening the hood. New ones are super stiff.
The ones I pulled would just flop in and out under their own weight.
Old Mar 29, 2010 | 01:47 PM
Flame Red's Avatar
Flame Red
How does one remove the old post on this bracket. I tired screwing off the bushing and it won't budge. Any ideas how to remove the old posts so bolts can be used to replace them. Looks like I can get all this at Home Despot.
Old Mar 29, 2010 | 09:00 PM
RED BARON's Avatar
RED BARON
I just picked up 2 new lifts for my 87 vert today from auto zone. They went on great but My hood still feels like it weighs a ton. I can see a little difference but nothing like I was expecting. This is my 3rd C-4 and none really lifted very easy. Are any of these rated stronger that another?
Old Mar 29, 2010 | 09:51 PM
tequilaboy's Avatar
tequilaboy
The upper posts are actually large D shaped rivets that are peened over on the backside of the brackets. You can cut off the peened over part and remove the post from the other side leaving a D shaped hole in the bracket. Be warned, this is a PIA since its a tight fit and the material is difficult to cut.
Old Mar 30, 2010 | 02:08 PM
Flame Red's Avatar
Flame Red
Thank you for that. Maybe a cut off wheel will help. Yes, it looks like it is quite substantial and would be a REAL PITA to remove. I was afraid of that.
I am guessing the equivalent set of struts (if they existed at all) that has the clips on the end would not work without a 'ball' mount? Those straight posts don't seem to have anything to 'grip'. Maybe if I could cut a notch in the post and hold the unit in with some kind of e-clip. But there would be so much tension on there I bet it would just pop off violently.
Or maybe I could use a tap and die and just thread the end of the little post!
Old Mar 30, 2010 | 08:59 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Originally Posted by WW7
Here you go, its offical, the 88 Vette only takes one shock..WW
http://www.ecklers.com/product.asp?p...6&dept_id=1459
OK but 2 are better. Price is too high. Try Rock Auto
Old Mar 30, 2010 | 09:12 PM
  #33
lostnfoundC4's Avatar
lostnfoundC4
Where they Mighty Lifts?
I replaced mine last year with a set I bought on ebay with no noticeable improvement either. They claimed to be OEM.
Old Mar 30, 2010 | 09:15 PM
  #34
samsonb's Avatar
samsonb
Maybe that means the old ones were still good?
Old Mar 30, 2010 | 09:23 PM
  #35
lostnfoundC4
They could have been but my hood still feels heavy as hell!
They sure don't work anywhere near as well as some describe.
