I have been researching much about headlight motor rebuilding lately, and finally got around to pulling out the drivers side light assembly this past weekend. I noticed on the passenger side, a device looking much like a small shock absorber on the inboard side of the right side head light. On the drivers side, I noticed the same kind of mounts, but no 'shock'. We have only had this car for 9 months, so I do not have much of the history of it. However, I believe if a part was meant to be there, it should be there. If you know about this part, and what it is called....I would appreciate hearing about it. Then I can start my search for one!
This is the best and easiset mod you can do,,, my hood will stay open at a 45 degree angle with the new hood shocks
Mighty-Lift / Support Lifts $17.99
For your 1985 Chevrolet Corvette 5.7L FI 8cyl
Part Number: F95056
Weight: 0.098 lbs
Notes: Hood 2 required
Extended Length: 6.38 in.
Compressed Length: 4.93 in.
Shaft Diameter: 10 mm.
Electric Terminals: No
Body Diameter: 22 mm.
Shaft Connection: Blade
Special Mounting Instructions: No
Quantity: Each sold separate
Body Connection: Blade
Stroke: 1.45
I believe they only came with the one shock on the passenger side. My 89 only has the shock on the passenger side. Though, it may help if you also put a shock on the driver side. My hood stays up no problem with only one shock.
Part Number: F95056
Weight: 0.098 lbs
Stroke: 1.45
My 89 only has 1 of the small shocks on the passanger side , I have seen another 89 also with only 1 of the shocks on the same side as mine so your car may have come from the factory with just 1 of these shocks plus the long hood shock on the drivers side....WW
Same as my 88. With 2 of these and the long support the clam shell will stay anywhere between open and closed.
I'd like it to where when you pop the hood, the hood raises all the way up by itself. I've heard of a few of these doing this. And I believe someone said Gordon Killbrew stated they all should do that.
I would love to have something like this for my 90 but I don't see where I have the mounting bracket for them. Can someone please post a picture that shows these mounts so I can look to see if I have them?
Hood Lift Support Sachs Clutches SG430011
Brand:
Part Number:SG430011
Price :$8.50
Additional Information
Warranty:
Category:Hood Lift Support
Description:Hood Lift Support
Condition:New
Req Qty:2
Note:Picture may be generic, please read description and check fitment notes.
Brand:
Price :$8.50
Warranty:
Condition:New
Req Qty:2
