CTSY Problem
Old Mar 23, 2010 | 12:55 PM
livetohunt54's Avatar
livetohunt54
Default CTSY Problem
My ctsy fuse keeps blowing everytime I hook up the battery,their is alot on this circut would like to know where to start
Old Mar 24, 2010 | 09:40 AM
Red Dwarf's Avatar
Red Dwarf
If you got a lot of items on that circuit, I'm assuming they are add-ons, then I'd disconnect a few & see if that corrects the problem?
Old Mar 24, 2010 | 12:26 PM
jfb's Avatar
jfb
Connect a 12v light bulb in place of the fuse and start disconnecting items powered by this fuse. If the light goes out, that device needs further looking into. If you have a wire pinched and shorting to ground, then you are going to have to inspect all wires connected to this fuse.
To CTSY Problem
