Door Sagging Help!!!!
Old Mar 24, 2010 | 11:44 PM
bpdfs's Avatar
bpdfs
Default Door Sagging Help!!!!
Passenger side door is sagging and the glass windows is hitting the frame of the car and scratching off paint... I was told the bushings and pins were worn out..
I went to autozone here locally and they do not have any in stock, said I have to go to dealer or another place in the area called Just CorVettes.. I called them and they only have the hinges???? Anyone got any ideas? how can i tell if its the hinges vs the pins and bushings??? Any help would be great!!!!
I found some on corvettecentral.com.. NOt sure what all i needed? If i wanted to do both doors, should i get 4 pins and 4 bushings?
1993 40th
Old Mar 25, 2010 | 12:14 AM
bpdfs's Avatar
bpdfs
please help as i need to get this resolved asap.
Old Mar 25, 2010 | 08:13 AM
bpdfs's Avatar
bpdfs
????? other people have had to have this issue too and got parts somewhere?
Old Mar 25, 2010 | 08:40 AM
Joe C's Avatar
Joe C
- my son's 85 has worn pin/bushings on the drivers door. the door saggs slightly. with the door open about 30 degrees, you can lift the door and feel the play in the door and the worn pins. the door probably moves up/down a 1/16" or so.
Old Mar 25, 2010 | 09:29 AM
npbassman's Avatar
npbassman
Zip corvette has em'.
http://www.zip-corvette.com/GroupDet...ge+%26+Spring&
Old Mar 25, 2010 | 09:40 AM
bpdfs's Avatar
bpdfs
what all do i need for 1 door? Do i need the spring also?
Old Mar 25, 2010 | 09:50 AM
npbassman's Avatar
npbassman
Two bushings for each pin. Shouldn't need a spring unless it's worn out or damaged.
Old Mar 25, 2010 | 09:52 AM
actionpaintball's Avatar
actionpaintball
X3 bushing and pin repair kit...its common on lots of GM cars and trucks....just did it on my Tahoe.
Old Mar 25, 2010 | 05:40 PM
Harry's 81 C3's Avatar
Harry's 81 C3
Default Sagging door
Try your local Chevy dealer for hinge pins. They come complete with the bushing. Another problem is if its been that way a while, your pin hole has wollowed and new pins will be a couple of year fix..
Less than $10. fix.. Harry
To Door Sagging Help!!!!
