problemsss pops and has codes
Old Mar 25, 2010 | 05:11 PM
mikeyboy's Avatar
mikeyboy
Cruising
Default problemsss pops and has codes
well i did my intake manfold gasket on the car now nothing leaks that turned out well. now for the problem he car runs starts right up but has codes and pops a little when idaling. the codes that are coming up are mass air flow , throtal pos sensor and air flow. now last year i replaced both of the sensors and i no for a fact that the throtal sensor is working becase if u push the tap the rpm go up.. what should be some things i check with these problem. the car had hese codes befor i did the gaskets it didnt run to good last year eather now im just trying to fix the problems
Old Mar 25, 2010 | 06:19 PM
surfer92's Avatar
surfer92
Ow man, learn english.
What year and was the THROTTLE position sensor set correctly and what are the error code numbers?
Old Mar 25, 2010 | 07:26 PM
mikeyboy's Avatar
mikeyboy
Cruising
thanks for the lession and its a 1987 and the sensor is correct
Old Mar 25, 2010 | 07:34 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
What are the codes ?
Old Mar 25, 2010 | 08:19 PM
mikeyboy's Avatar
mikeyboy
Cruising
mass air flow sensor ,throttle position sensor, and air flow
Old Mar 25, 2010 | 10:04 PM
RRT vette's Avatar
RRT vette
Have you cleared the codes?
Do you have a factory service manual?
After you disconnect the neg cable to clear the codes (or pull the ecm fuse), start the engine and see if any codes return. If they do, then you will need a service manual to troubleshoot each code. That is where I would start. Search for vacuum leaks and double check all the wiring and connections.
Old Mar 25, 2010 | 10:57 PM
AGENT 86's Avatar
AGENT 86
Sorry, I'm talking about the numbers, as in code 33, 22 etc
Old Mar 26, 2010 | 11:53 PM
mikeyboy's Avatar
mikeyboy
Cruising
no i dont have the number for codes. i was thinking does those two sensors have a comon ground? could the ground be messed up making both sensors messged up
Old Mar 27, 2010 | 12:08 AM
Mark85Vett's Avatar
Mark85Vett
how do you know these are the trouble spots without having the codes??
Old Mar 27, 2010 | 08:17 AM
AGENT 86's Avatar
AGENT 86
The sensors you mentioned, have more than one trouble code.
Pull the codes and post the numbers.
http://members.shaw.ca/corvette86/No...it%20Check.pdf
Old Mar 28, 2010 | 06:19 PM
mikeyboy's Avatar
mikeyboy
Cruising
ok i have to borrow the scanner again
Old Mar 28, 2010 | 10:42 PM
AGENT 86's Avatar
AGENT 86
You don't need a scanner, you need a paper clip to jump terminals "A" and "B" on the ALDL port.
To problemsss pops and has codes
