My hunt for a Driver's side seat bolster switch continues:
I saw a switch for sale on ebay - it is listed as a replacement for 87-90 Corvettes. Is the switch the same as my broken one (in my 1992)? Will it plug and play, or would it take modification to make it work?
Throw my name in also, I need two. I don't know what is wrong with mine, it's now adjusted for a slim person and a 230 lb man doesn't fit comfortably. Wish I could just let it out and fix later, BUT???
Harry
Harry
Here's a free fix for you until you find a new switch: Disassemble the old switch so you can get to the contacts inside. Then supply 12V to the terminals . Swap the + and - to operate the bolster motor in the direction you need. I did this on my 92, and since no one else drives the car, I'm fine with not having an operable switch.
