Ring And Pinion Question...
Old Mar 26, 2010 | 07:17 PM
JeepCycle's Avatar
JeepCycle
Default Ring And Pinion Question...
The C4 Manual trans differential is an aluminum case Dana 44.
My Jeep Grand Cherokee has an aluminum case Dana 44.
Does the ring and pinion from one Dana 44 aluminum case diff fit another?
I know that they do not interchange from a regular Dana 44 Iron case...but I was wondering...if nobody knows...who can I contact?
Old Mar 26, 2010 | 07:41 PM
WVZR-1's Avatar
WVZR-1
What year is your GC? Post the VIN or maybe just the last 9 of the VIN and I'll explain!!!
Old Mar 26, 2010 | 09:00 PM
neat's Avatar
neat
It won't work. The pinion diameter is different on the Corvette.
Old Mar 26, 2010 | 09:10 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
We have the super Dana 44, larger pinion.
Old Mar 26, 2010 | 09:26 PM
redrose's Avatar
redrose
C4 manual trans 85-96 and vapors use a crossbred D44/D60 with the D60 pinion shaft...an industrial bearing supply house can do a small bit of research and provide readily available bearings to install the truck D44 pinion, the truck d/s yoke and seal fit the vette case (BTDT)
Old Mar 26, 2010 | 11:53 PM
WVZR-1's Avatar
WVZR-1
I wanted to use the information from the OP's GC for an example after a check of his build BUT in a "general response" for some GC builds yes the "ring and pinion gear set is a fit". The D44HD is used in some ZJ builds. One of the most popular gear sets for the D44HD "Vette/Viper" is an OE build for the ZJ.
The gear set 707381-4X is a 3.73 from a Dana build 605735-2, 605962-2 (trac-lok) and 605735-3, 605962-3 (open).
There's a less popular 707381-3X which is a 3.55 that will do also.
Is the OP's a FIT? I don't know and I asked for information to confirm before I just "tossed BS information" out there.
Old Mar 26, 2010 | 11:56 PM
missinganova's Avatar
missinganova
That is a great question; unfortunately I have no idea what the answer is.
Honey, grab me another Miller Lite.
Old Mar 27, 2010 | 05:12 PM
JeepCycle's Avatar
JeepCycle
Thanks to all of you.
I'm not taking the gears from my Jeep but am looking to avoid the Vette surtax!
To Ring And Pinion Question...
