front still sitting high
Old Mar 26, 2010 | 09:37 PM
danamals16's Avatar
danamals16
Default front still sitting high
i lowered my 94 and the rear is low but the front is still high i only put one spacer on each side my question is will it set after driving it for a while or did i mess something up
Old Mar 27, 2010 | 08:22 AM
MRDZR1's Avatar
MRDZR1
You removed one spacer up front? Therefore there's one left? If so take it off and you'll gain an other 5mm.
Here's my ZR1 with out the 2 spacers up front.
http://s754.photobucket.com/albums/x...n%20up-grades/
Old Mar 27, 2010 | 08:41 AM
Weav's Vet's Avatar
Weav's Vet
It'll settle some but you should have removed all the shims for max lowering. You may be able to get it a little lower by removing the rubber pads on the end of the spring. That way you won't have to do it all again.
To front still sitting high
