Jacking with ground effects?
Old Mar 27, 2010 | 10:22 AM
My1st's Avatar
My1st
Default Jacking with ground effects?
My 89 Coupe has ground effects. What’s the best way to raise the car to put jack stands under it?
I’ve read a lot of threads on jacking but none were about having ground effects that I have seen.
From what I can tell without raising the car the bottom part of the effects is covering the frame rail were the normal jacking points are.
Old Mar 27, 2010 | 10:32 AM
lushdrunk's Avatar
lushdrunk
$130 at northern tool
It is only 3" tall and stays 3" tall for 22"
Its the best jack ive seen for low ground effect cars. I bought after I lowered my 99 ss camaro it to had side ground effects.
Only downside to the jack is it is 109lbs ! but it is also very long and low and lifts from 3" to 22" and rated at 3 ton. Its a nice jack.
You can also drive up on some 2x6's to get more clearance. Ive had to do that many of times.
Old Mar 27, 2010 | 10:34 AM
WW7's Avatar
WW7
The ground effects stops short of the jacking points, you just need to have a jack thats low enough to fit under the car with the ground effects on..WW
Old Mar 27, 2010 | 11:11 AM
qws's Avatar
qws
Before I had a low profile jack I used to drive up on a couple of 2 x 4's first then jack it up. It will give you an added inch and half
Old Mar 27, 2010 | 12:18 PM
My1st's Avatar
My1st
Is it safe to raise the cars using a floor jack under the front cross member and for the rear under the differential?
Old Mar 27, 2010 | 01:10 PM
qws's Avatar
qws
I use the front crossmember but always place my rhino ramps under the front tires just for safety.
Old Mar 27, 2010 | 02:29 PM
pologreen1's Avatar
pologreen1
Front, and on my vert I use the X brace too.
Old Mar 27, 2010 | 02:30 PM
pologreen1's Avatar
pologreen1
lushdrunk
Is that your car? I have seen it used in ads for corvette central and mags.
Old Mar 27, 2010 | 04:22 PM
JAKE's Avatar
JAKE
My previous 86 had ground effects and I use to have to drive the car up on three 2x6 boards I screwed together in a stair-step fashion in order for me to position the jack under a suspension member.
Jake
Old Mar 27, 2010 | 05:01 PM
My1st's Avatar
My1st
Ended up using the ZR1 way I saw a post on using a hockey puck on the jack. It worked well with little effort other then using a scissor jack to get the car high enough to get the floor jack under it. Thanks for all the responses. It's beer thrity now!
To Jacking with ground effects?
