TPI Runner fitment?
Old Mar 27, 2010 | 11:32 AM
JeepCycle's Avatar
JeepCycle
Default TPI Runner fitment?
The RUNNERS from the l98 TPI.
Are they interchangeable for all l98 tpi's?
I have a chance to purchase a set of polished runners and need to know if they will fit my 85 l98 tpi manifold.
Thanks,
JC
Old Mar 27, 2010 | 12:12 PM
engle1147's Avatar
engle1147
The passenger side runner is exactly the same for 85-91 but the drivers side runner is different for 85-88 as compared to 89-91.
85 - 88 runner sets are exactly the same and are interchangable between these years but they are different when you compare them to the 89-91 runner sets. The difference is the early ones have an extra tube (smaller)/opening for the cold start on the "driver's side" and the later ones (89-91)do not have the opening / tube provision.
The bolt patterns are identical for all TPI runner sets....so they will all bolt up to a degree.
Below is a pic of an aftermarket SLP runner set (for an 89-91)without the CSI tube for the driver's side.... the tube for the driver's side (runner on the left in the picture) has been blocked off by the manufacturer. The hole in the other runner (passenger side is there for the EGR.
Old Mar 27, 2010 | 05:10 PM
JeepCycle's Avatar
JeepCycle
Thank you that was very helpful.
Old Mar 28, 2010 | 12:22 PM
MrVette90l98mt's Avatar
MrVette90l98mt
Does anybody know for sure if the runners are interchangible left and right?
I ask this because I got a pair for free (both have tubes and a bevel to match plenum near the throttle body). They are dinged up and plan on siemessing them just for fun.
I have a 90 with what appears to be the earlier setup on the car(tubes on both sides). I know this is not factory stock because I do not have a cold start injector, looks like some one had to replace them because they damaged them.
Any help will be very helpful.
To TPI Runner fitment?
